23.08.2023, 11:43
		Remove Security System Target State Status (uint8) as this is totally different value then the previous two.
					Homekit app
		23.08.2023, 11:43
------------------------------ Ctrl+F5
		18.09.2023, 10:26
		Hello, I have configured the Homekit application in logic Machine and work perfectly, but when I leave the local network it does not work.  Is a Homepod necessary to use the application outside the local network? Thanks!
		18.09.2023, 10:31
		Yes, Homepod is needed for this.
		20.09.2023, 06:49
		Ok thanks!
		25.09.2023, 11:05
		is Homepod needed or can Apple TV be used? If I add it, the HomeKit App does not work in LogicMachine... Sent from my iPhone using Tapatalk
		25.09.2023, 12:42
		We don't have apple TV to test so hard to say, it works with homepod as many users already confirmed.  Do you have any error logs in the Homekit app?
		25.11.2023, 09:11
		I've been using the HomeKit integration for a little while and it's great and generally works well, but a few things I've found that are missing that would make it perfect for me:
		23.01.2024, 11:11
		Dear Admin, in the video you use RGB lighting but what datapoints did you connect as the homekit app only now shows (rgb) as value and nothing more. (yours show on/off and RGB But it is not clear what kind of datatype the RGB value is)
		09.02.2024, 20:31
		Is it possible to get Hikvision NVR stream into home app? There is some information in documentation but maybe someone have some code what to share... I have no idea where to start...
		12.02.2024, 08:32
		You need some extra software to convert the camera stream to a format that Homekit understands and some hardware like RPi to run it.
		25.02.2024, 17:30
		Is there a max on homekit devices?
		26.02.2024, 05:44
		Limit is 150 devices.
		27.03.2024, 14:34
		Hello! I'm getting these errors in Homekit log: Code: 2024.03.27 14:25:05 [Core:IPAccessoryServer] Out of resources (outbound buffer too small).Also in app, system shows "Updating" quite long time (about 20-40 seconds). I have about 70 devices (30 dimmable lamps, 13 smoke sensors, 13 moving sensor, 12 room thermostats and few curtains). Firmware Version: 20240219 Homekit app : 20240205 Does this on both newtorks - local and via 4G
		27.03.2024, 15:02
		Check PM
		28.03.2024, 11:04
		20.04.2024, 16:29
(This post was last modified: 20.04.2024, 16:30 by davidkoch29.)
		20.04.2024, 16:31
		Update the app from the store.
		08.05.2024, 06:44
		Hello, I can't link the LM bridge with the home app. I scan the QR and after several minutes it mentions that the accessory was not found.
