traffic light effect
Hello
Is it possible to create 4-5 lamps that will work like a traffic light, one turns on and the other turns off in cycles? If the enable option is disabled Shy . Thanks
Use this resident script. Sleep time controls when the next lamp will be turned on. Any number of objects can be specified.
objects = {   '0/0/1',   '0/0/2',   '0/0/3', } curr = (curr or 0) + 1 if curr > #objects then   curr = 1 end if prev then   grp.checkwrite(objects[ prev ], false) end grp.checkwrite(objects[ curr ], true) prev = curr
This script can be enabled/disabled from a different script using these functions: https://kb.logicmachine.net/libraries/lu...enablename
(02.05.2024, 07:38)admin Wrote: Use this resident script. Sleep time controls when the next lamp will be turned on. Any number of objects can be specified.
objects = {
  '1/0/51',
  '1/0/53',
  curr = 1
if prev then
prev = curr
Hello, I put the data in this way, where do I see the time it is supposed to change, it doesn't work, I work with a Schneider LS 100 200 product, thanks
Did you use resident script? The script interval defines the change.
