	Threads: 1
Has anyone done a WLED integration? Tried searching the forums (and google), without luck. My goal is to use KNX+ LM visualization to control WLED (on/off, dim, color, effects).
I've also tried looking at other json scripts, but its quite difficult to understand with zero lua scripting knowledge...
The WLED page on json isn't very helpful (https://kno.wled.ge/interfaces/json-api/ )
WLED also support MQTT (https://kno.wled.ge/interfaces/mqtt/ ), but that was even more difficult to understand
--Dan
	Threads: 45
		Example for brightness control.
Attach an event script to 0..100% scale object. Change WLED_IP to your WLED device IP address.
 Code: http = require('socket.http')json = require('json')
 ltn12 = require('ltn12')
 url = 'http://WLED_IP/json/state'
 value = event.getvalue()
 data = json.encode({
 on = value > 0,
 bri = math.round(value * 2.55),
 res, code = http.request({
 url = url,
 method = 'POST',
 headers = {
 ['content-type']  = 'application/json',
 ['content-length'] = #data,
 source = ltn12.source.string(data),
 log(res, code)
	Threads: 16
		 (20.05.2024, 20:43)danborge Wrote:  Hi,
 The WLED page on json isn't very helpful (https://kno.wled.ge/interfaces/json-api/)
 WLED also support MQTT (https://kno.wled.ge/interfaces/mqtt/), but that was even more difficult to understand
 --Dan
I have developed a pretty good library if you want. It just controls one segment though, but you can adapt it a little to control more than one
	Threads: 1
		21.05.2024, 18:05
(This post was last modified: 21.05.2024, 18:06 by danborge.)
		 (21.05.2024, 11:37)Andrea Becagli Wrote:   (20.05.2024, 20:43)danborge Wrote:  Hi,
 --Dan
Thanks, that would be great    Got one segment on two different ESP32s, so its just what I'm looking for.
  (21.05.2024, 07:24)admin Wrote:  Example for brightness control.
 on = value > 0,
 url = url,
 method = 'POST',
 headers = {
 log(res, code)
Thanks, I'll make a script and try this
	Threads: 16
		22.05.2024, 15:31
(This post was last modified: 22.05.2024, 15:37 by Andrea Becagli.)
		There you go, I will attach the library i made. Sorry I am italian so most of the comments are in italian Code: json = require('json')http = require('socket.http')
 wled_ctrl = {
 defaults = {
 debug_mode = false,
 token = nil
 Tutta la documentazione sulla Api puo essere ritrovata a https://kno.wled.ge/interfaces/json-api/.
 Per usare questa libreria sará necessario creare degli oggetti a cui poi collegare uno script su evento
 in cui richiamare le varie funzioni.
 Es. indirizzo di gruppo 0/0/1 COMANDO ON-OFF WLED verra collegato allo script su evento
 local on_off = event.getvalue()
 wled = wled_ctrl:init({ip = {{IP}}, debug_mode = false})
 wled:accensione(on_off, ga_stato)
 ----- CREAZIONE DELLA CLASSE WLED CONTROLLER -----
 function wled_ctrl:init(params)
 local n = setmetatable({}, { __index = wled_ctrl })
 local k,v
 -- set user parameters
 n.params = params
 for k, v in pairs(wled_ctrl.defaults) do
 if n.params[ k ] == nil then
 n.params[ k ] = v
 return n
 ----- RICHIESTA POST HTTP GENERICA -----
 function wled_ctrl:basic_post_req(body_req)
 res, err = http.request({
 url = 'http://'..self.params.ip..'/json/state',
 method = "POST",
 body = body_req,
 headers = {["Content-Type"] = "text/plain"}
 return res,err
 ----- ACCENSIONE -----
 function wled_ctrl:accensione(valore, stato)
 body1= '{"on":'..tostring(valore)..'}'
 res,err = self:basic_post_req(body1)
 if err == 200 then grp.write(stato, valore) end
 if self.params.debug_mode and err ~= 200 then log("accensione - Error: "..tostring(err)) end
 ----- LUMINOSITA -----
 function wled_ctrl:luminosita(valore, stato)
 body1= '{"bri":'..tostring(math.floor(valore*2.55))..'}'
 if self.params.debug_mode and err ~= 200 then log("luminosita - Error: "..tostring(err)) end
 ----- COLORE -----
 function wled_ctrl:colore(valore, stato)
 hexcolor = string.format("%X",tostring(valore))
 while hexcolor:len() < 6 do
 hexcolor = "0"..hexcolor
 log(hexcolor)
 body1= '{"seg":[{"col":["'..hexcolor..'"]}]}'
 if self.params.debug_mode and err ~= 200 then log("colore - Error: "..tostring(err)) end
 ----- EFFETTI -----
 function wled_ctrl:effetto(valore, stato)
 body1= '{"seg":[{"fx":'..tostring(valore)..'}]}'
 if self.params.debug_mode and err ~= 200 then log("effetto - Error: "..tostring(err)) end
 ----- COLOR TEMP -----
 function wled_ctrl:color_temp(valore, stato)
 body1= '{"seg":[{"cct":'..tostring(valore)..'}]}'
 if self.params.debug_mode and err ~= 200 then log("color temp - Error: "..tostring(err)) end
 ----- PALETTE -----
 function wled_ctrl:palette(valore, stato)
 body1= '{"seg":[{"pal":'..tostring(valore)..'}]}'
 if self.params.debug_mode and err ~= 200 then log("palette - Error: "..tostring(err)) end
 ----- STATO -----
 function wled_ctrl:stato()
 res,err = self:basic_post_req('{}')
 local info = json.decode(res)
 if self.params.debug_mode then log("Response: "..tostring(res).." Error: "..tostring(err)) end
 return {
 accensione = info.state.on,
 luminosita = info.state.bri,
 colore =info.state.seg[1].col[1],
 effetto = info.state.seg[1].fx,
 palette = info.state.seg[1].pal
	Threads: 1
		 (22.05.2024, 15:31)Andrea Becagli Wrote:  There you go, I will attach the library i made. Sorry I am italian so most of the comments are in italian
 wled_ctrl = {
 defaults = {
 debug_mode = false,
 token = nil
 local k,v
 n.params = params
 n.params[ k ] = v
 return n
 method = "POST",
 body = body_req,
 return res,err
 ----- COLORE -----
 log(hexcolor)
 ----- EFFETTI -----
 ----- PALETTE -----
 ----- STATO -----
 return {
 Thanks. I'll test this    No problem with the Italian, google translate if its something I dont understand
	Threads: 84
long time ago I used very interesting project with ESP8266 and ws2812 LEDs. It was Tobias Blum's MC lighting project.
Some links I found below.
https://github.com/toblum/McLighting/
https://github.com/FabLab-Luenen/McLighting
https://hackaday.io/project/122568-mc-lighting
https://www.hackster.io/news/mclighting-...b1705a44de
Why I decided to mention it - you can very easy control yours WLED's over WiFi with mobile phone, and main - using your LM/SL/HL and just REST API commands - only one line string commands.
Possible to change WLED effects, colors, On/Off, Dimm etc. I also created color clock - at 7:00 all wleds are green, at night all are red etc
Alexander
