08.08.2024, 11:08
Hello. Standart RGB mosaic widget for 3byte color have dimmer slider, but widget for visualisation don't have it. How to add slider to 1.widget?
standart RGB widget
08.08.2024, 11:08
08.08.2024, 11:34
RGB color picker does not use a slider because you can select both color and intensity/brightness using a single picker. It's not possible to add a slider there.
08.08.2024, 16:04
(08.08.2024, 11:34)admin Wrote: RGB color picker does not use a slider because you can select both color and intensity/brightness using a single picker. It's not possible to add a slider there. Hi admin, I take the opportunity to ask if it is possible in the future add colour picker in a mosaic widget. Best regards Cristian
12.08.2024, 08:29
Thanks for the suggestion but Mosaic is not developed anymore. Only bug fixes are provided.
18.08.2024, 20:43
