standart RGB widget
Hello. Standart RGB mosaic widget for 3byte color have dimmer slider, but widget for visualisation don't have it. How to add slider to 1.widget?
RGB color picker does not use a slider because you can select both color and intensity/brightness using a single picker. It's not possible to add a slider there.
(08.08.2024, 11:34)admin Wrote: RGB color picker does not use a slider because you can select both color and intensity/brightness using a single picker. It's not possible to add a slider there.
Hi admin,
I take the opportunity to ask if it is possible in the future add colour picker in a mosaic widget.
Best regards Cristian
Thanks for the suggestion but Mosaic is not developed anymore. Only bug fixes are provided.
(12.08.2024, 08:29)admin Wrote: Thanks for the suggestion but Mosaic is not developed anymore. Only bug fixes are provided.
eta on the new "app"? Can't wait
