trends fetch
There's something that i can't understand on trends.fetch function...
If I call it like this, returning timestamps should be in UTC, isn't it?
local dates = {   ['start'] = os.time({ year = 2024, month = 9, day = 2, hour=0 , min=0, sec=0},true),   ['end'] = os.time({ year = 2024, month = 9, day = 3, hour=0 , min=0, sec=0},true), } local yearly = trends.fetch('Trend - Data', dates, nil, true) local i for i=1,3,1 do log(i,yearly[i]) end
These are log values:
sample 04.09.2024 12:11:31 * arg: 1   * number: 1 * arg: 2   * table:    [1]     * number: 1725238800    [2]     * number: 60032.77 sample  04.09.2024 12:11:31 * arg: 1   * number: 2 * arg: 2   * table:    [1]     * number: 1725242400    [2]     * number: 60033.42 sample  04.09.2024 12:11:31 * arg: 1   * number: 3 * arg: 2   * table:    [1]     * number: 1725246000    [2]     * number: 60034.42
Attached there is an image from trends visualitzation:
I thought that on trend visualitzation data is shown in local time but values corresponds to UTC timestamps... Can someone explain me if i'm missing something?
What is your LM timezone?
(04.09.2024, 10:29)admin Wrote: What is your LM timezone?
Europe/Madrid
The timestamp is not exactly UTC but the current timestamp is used as if it was a UTC time. This is needed for days start at 0:00, otherwise the daily data calculation will be wrong.
Use this to convert trend timestamp to a formatted date string:
os.date('!%d %m %Y %H:%M',value[1])
(04.09.2024, 13:11)admin Wrote: The timestamp is not exactly UTC but the current timestamp is used as if it was a UTC time. This is needed for days start at 0:00, otherwise the daily data calculation will be wrong.
So if I understant it, inside rrd you're storing a "local timestamp" like this:
  if now it's "04/September/24 14:00:00 GMT+02:00 DST" you store this timestamp 1725451200+2*3600
Isn't it?
(04.09.2024, 14:08)jmir Wrote: So if I understant it, inside rrd you're storing a "local timestamp" like this:
Yes
Yes
Ok thanks!
