14.12.2024, 17:30
Is it possible to execute a script or update a GA using http command? http://IPaddress etc etc etc?
Run script or update GA from http command
14.12.2024, 17:30
14.12.2024, 17:55
(14.12.2024, 17:30)tomnord Wrote: Is it possible to execute a script or update a GA using http command? http://IPaddress etc etc etc? Hi, check this: https://kb.logicmachine.net/misc/remote/ BR Cristian
15.12.2024, 19:24
(14.12.2024, 17:55)CristianAgata Wrote:(14.12.2024, 17:30)tomnord Wrote: Is it possible to execute a script or update a GA using http command? http://IPaddress etc etc etc? Brilliant, missed that one when browsing!
16.12.2024, 08:38
(14.12.2024, 17:55)CristianAgata Wrote:(14.12.2024, 17:30)tomnord Wrote: Is it possible to execute a script or update a GA using http command? http://IPaddress etc etc etc? Do you always have to enter credentials when running remote services? I get prompted for login on LM even when password is in the url command.
16.12.2024, 08:40
Remote services are designed to be used for integration with other systems, not for user interaction.
16.12.2024, 10:47
16.12.2024, 12:04
You can try this but no security:
https://forum.logicmachine.net/showthrea...7#pid20407
16.12.2024, 14:10
(16.12.2024, 12:04)Daniel Wrote: You can try this but no security: Thanks, I'll have a look. It's just for use on wifi. for triggering events with a QR-code or similar.
17.12.2024, 06:09
A more secure approach is to create a separate .lp file for each action (QR code) without any parameters.
Code: 123 <?
require('apps')
grp.write('1/1/1', true) |
