Run script or update GA from http command
Is it possible to execute a script or update a GA using http command? http://IPaddress etc etc etc?
(14.12.2024, 17:30)tomnord Wrote: Is it possible to execute a script or update a GA using http command? http://IPaddress etc etc etc?
Hi, check this:
https://kb.logicmachine.net/misc/remote/
BR Cristian
Hi, check this:
BR Cristian
Brilliant, missed that one when browsing!
Hi, check this:
BR Cristian
Do you always have to enter credentials when running remote services? I get prompted for login on LM even when password is in the url command.
Remote services are designed to be used for integration with other systems, not for user interaction.
(16.12.2024, 08:40)admin Wrote: Remote services are designed to be used for integration with other systems, not for user interaction.
Is there any other way to run commands via url then?
You can try this but no security:
https://forum.logicmachine.net/showthrea...7#pid20407
(16.12.2024, 12:04)Daniel Wrote: You can try this but no security:
Thanks, I'll have a look. It's just for use on wifi. for triggering events with a QR-code or similar.
A more secure approach is to create a separate .lp file for each action (QR code) without any parameters.
<? require('apps') grp.write('1/1/1', true)
