Ping IP doesn't work
I am using this script: https://forum.logicmachine.net/showthread.php?tid=1035 to ping an IP adress of a laptop in the same network as the LM is. It somewhy does not work, I transformed script into this:
function socketping(ip, port, timeout)
  port = port or 80
  local sock = require('socket').tcp()
  sock:settimeout(timeout or 20)
  local res, err = sock:connect(ip, port)
  log(res)
  log(err)
  sock:close()
  return res, err
ip = '192.168.100.149'
if socketping(ip) then
  log('CONNECTED')
  grp.write('0/0/9', true)
  log('DISCONECTED')
But it always logs disconected, no matter what I try. If I ping the IP from cmd, it pings fine. Where could be the problem?
Thank You.
Log what error tells you. You need to check on which port you can access this PC. Most likely firewall blocks it. I tested it with another LM and the script itself works.
This is not standard ping. It tries to connect to port 80, so unless you have a web server running on laptop it will not work.
Use this function instead:
function ping(ip)
  local res = os.execute('ping -c 2 -W 5 ' .. ip)
  return res == 0
Thank You guys. I've tried the script, but now it always logs that the IP is connected even though it is on another network. I don't understand, if there is something I'm doing wrong? Here is the script:
function ping(ip)
  return res == 0
ping('192.168.100.222')
if ping then
  log('Connected')
  log(ping)
  --grp.checkwrite('0/0/9', true)
  log('Disconected')
  --grp.checkwrite('0/0/9', false)
If I ping this IP from cmd the request times out and it is disconected, but if I run this script it says it is connected. Maybe I have to somehow decode the data from "res"?
This is what logs gives me:
Ping IP 08.08.2019 11:04:40
* string: Connected
* function: 0xb6b9d158
Correct your line 6 to this
ping=ping('192.168.100.222')
Thank You Daniel, it works perfectly Smile
I want to use ping function for many IP check in one script, but how correctly to use function many times?
I did this way but error.. Resident script:53: attempt to call global 'ping' (a boolean value)
stack traceback:
Error apear when I want to use function with other IP..
function ping(ip)
  return res == 0
ping=ping('192.168.45.1')
if ping then
  --log('Connected')
  --log(ping)
  grp.checkwrite('11/0/1', true)
  log('Disconected')
  grp.checkwrite('11/0/1', false)
ping=ping('192.168.45.2') --line 53
if ping then
  --log('Connected')
  --log(ping)
  grp.checkwrite('11/0/2', true)
--else
  --log('Disconected')
  grp.checkwrite('11/0/2', false)
ping=ping('192.168.45.205')
if ping then
  --log('Connected')
  --log(ping)
  grp.checkwrite('11/0/3', true)
  grp.checkwrite('11/0/3', false)
ping=ping('192.168.45.235')
if ping then
  --log('Connected')
  --log(ping)
  grp.checkwrite('11/0/4', true)
  grp.checkwrite('11/0/4', false)
ping=ping('192.168.45.210')
if ping then
  --log('Connected')
  --log(ping)
  grp.checkwrite('11/0/5', true)
  grp.checkwrite('11/0/5', false)
Alex
It does not work because you've set the result to variable with the same name as the function. So ping is no longer a function but boolean variable.
Another thing is that if/else is not needed, you can pass the result directly to checkwrite:
function ping(ip)
  return res == 0
res = ping('192.168.45.1')
grp.checkwrite('11/0/1', res)
OK,
Big thanks for correcting our mistakes ans possibility to learn right ways of LUA programming!
Alex
Hi All!
The solution doesn't work on LSS100200.
My script is follow:
function ping(ip)
  return res == 0
-- res = ping('10.25.90.209')
res = ping('10.25.90.12')
grp.checkupdate('5.SHAVIP.2_MEGateway_Status', res)
In error log I see this:
os.execute call blocked
Disable "Block unsafe functions in scripts" in Utilities > General configuration.
Dear admin,
is there any concerns using telnet in this way, while I got response as ping  0 == succeed
os.execute('telnet ' .. ip .. port)
Best Regards,
Instead of executing ping/telnet you can try connecting to a known open TCP port on a device if it has one.
function pingtcp(ip, port)
  sock:settimeout(1)
  sock:close()
  return res, err
res, err = pingtcp('192.168.1.1', 80)
log(res, err)
(30.01.2025, 11:35)admin Wrote: Instead of executing ping/telnet you can try connecting to a known open TCP port on a device if it has one.
  sock:settimeout(1)
  sock:close()
  return res, err
log(res, err)
thank you
does this work with ftp port 21?
Best Regards,
It should work with any service that uses TCP - HTTP, FTP, Telnet, SSH etc.
