Epiphan recording
I have a customer that want to start and stop recording from a http request, and even feedback.
Got these url from the manager,
Start recording   http://192.168.0.5/admin/channel1/set_params.cgi?publish_enabled=on Stop recording;  http://192.168.0.5/admin/channel1/set_params.cgi?publish_enabled=off Feedback that shows if it on or off :    http://192.168.0.5/admin/channel1/get_params.cgi?publish_enabled=on
I want to have a button that turn on/off the recording and a feedback object.
require('socket.http') socket.http.TIMEOUT = 15 value = event.getvalue() if value == false then    socket.http.request('http://192.168.0.5/admin/channel1/set_params.cgi?publish_enabled=off') else value == true then    socket.http.request('http://192.168.0.5/admin/channel1/set_params.cgi?publish_enabled=on') end
Is is the right way to do it?
How can i get feedback to a 1bit object that shows 1 or 0?
Event script can be simplified a bit:
http = require('socket.http') value = event.getvalue() param = value and 'on' or 'off' http.TIMEOUT = 15 http.request('http://192.168.0.5/admin/channel1/set_params.cgi?publish_enabled=' .. param)
You will need a resident script for polling the status (with non-zero sleep time):
http = require('socket.http') http.TIMEOUT = 15 res = http.request('http://192.168.0.5/admin/channel1/get_params.cgi') log(res)
Post what you get in LM Logs tabs when running this script.
This is what I get when i run the feedback.
* string: <HTML> <body>   <h1>Credentials required</h1>   <p>Username and password are required to access this Epiphan device. Reload the page and try again.</p> </body> </HTML>
Now I have the admin and password for the camera. But when I read this page,  https://www.epiphan.com/userguides/pearl...h_http.htm
I'm bit confused where to put the password, in the page they use wget? when they use admin and password to access the camera.
Where do I put the password in the http request?
Try putting credentials into the URL: http://user:password@192.168.0.5/...
Got the same message...
* string: <HTML>
<body>
</body>
</HTML>
Your device might use digest authentication mechanism. Try code from this post: https://forum.logicmachine.net/showthrea...64#pid9364
Just got it to work with
http = require('socket.http') http.TIMEOUT = 15 res = http.request('http://admin:password@192.168.0.5/admin/channel1/get_params.cgi?publish_enabled=on') log(res)
The log answer is:
Feedback inspelning 15.05.2025 20:27:39 * string: publish_enabled = on Feedback inspelning 15.05.2025 20:27:44 * string: publish_enabled = off
How to convert it to a 1bit object on/off?
Change 1/1/1 to your status group address:
http = require('socket.http') http.TIMEOUT = 15 res = http.request('http://admin:password@192.168.0.5/admin/channel1/get_params.cgi?publish_enabled=on') if res then   value = res:find('on') ~= nil   grp.checkwrite('1/1/1', value) end
