Open beta testing
Hi, I’ve done some tests using the plan visualization, and I’ve noticed that the size and/or position of objects changes depending on the device used or whether it's accessed through the cloud or not..
Visu using Laptop:
Using mobile direct connection:
Using mobile cloud connection:
(27.08.2025, 17:28)linux_sun Wrote:
(27.08.2025, 17:08)Daniel Wrote: You cant sent: 2,3,4,5... to a boolean object
I know that. I was asking because Mosaic has the widget shown in my previous screenshot. Does Visu have something similar, or is it planned?
No we will not as full solution is already implemented for this point. Visu is a mixture of Mosaic and old Visualization. Some ideas are taken from one and some from the other depend where it was done better.
@jmir, This looks to me as a custom font. The label element has auto-sizing and different browser is doing it slightly different. We will add size to the label element and there will not be auto-sizing.
Ahhh, too bad, because it was a very useful command. I’ll replace it with a script. Thanks.
@linux_sun, can you explain what exactly is missing? If you want to send a fix Boolean value you should use Switch widget with Switch mode set to "Send On" or "Send Off". If you want to send a fixed numeric value then use the respective widget. The logic is different from Mosaic but the end result is the same.
(28.08.2025, 08:41)admin Wrote: @linux_sun, can you explain what exactly is missing? If you want to send a fix Boolean value you should use Switch widget with Switch mode set to "Send On" or "Send Off". If you want to send a fixed numeric value then use the respective widget. The logic is different from Mosaic but the end result is the same.
@admin, let me try to clarify the situation more precisely:
I'm working with the DTPs shown in figure (a). Although they are defined as switches, they actually operate according to the following logic:
DTP 41 fires when it receives the value 1
DTP 42 fires when it receives the value 2
DTP 43 fires when it receives the value 3
DTP 44 fires when it receives the value 4
In Mosaic (see figure (b)), this behavior could be implemented using the Send Fixed Value widget. However, in Visu this doesn't seem to be possible: when using the Select Value widget (or any other suitable widget, see figure ©), selecting the switch DTP is not allowed, as shown in figure (d).
Thanks in advance for your support.
Switch is a switch, it can have two states: True and False. If you write any none-zero value to a boolean object you will get True. It is not that your 4 objects need a different value to work, any none zero value would do. This still doesn't change that simple 0/1 will do exactly the same. Just use Switch element with Mode set to: Send On(1) and end result will be exactly the same as writing 1, 2, 3 or 4.
I created a layout with an image as background and associated it to a plan, but I can't see the background layout over it as previous in scada-vis. Why?
Check that your plan background is transparent. Also check Global appearance settings > Backgrounds > Plan view background.
(02.09.2025, 09:27)admin Wrote: Check that your plan background is transparent. Also check Global appearance settings > Backgrounds > Plan view background.
yes, the problem was color on backgrounds global settings.
Peppe
New version of Visu is ready here
Changes:
  • Many bug fixes and minor design tweaks under the hood
  • Plan/Layout/Widget group replacement (in the menu) has a object selection.
.ipk   visu-20250926.ipk (Size: 777.39 KB / Downloads: 10)
