Control Nefit boiler
I like to control a Nefit boiler that has an EMS protocol. Its not possible to control it directly so i inserted an EMS-ESP into my system.
Now i can get data from my system with this script
--[[ Nefit heat pump ems bus https://bbqkees-electronics.nl/wiki/gateway/restful-api.html https://docs.emsesp.org/Commands/ ems-esp/boiler                                        {"cmd":"heatingactivated", "data":"on"}        turn on heatingactivated in boiler ems-esp/boiler/heatingactivated        {"data":"on"}                                                            turn on heatingactivated in boiler (equivalent to command above) ems-esp/boiler                                        {"cmd":"dhw.disinfecting", "data":"on"}        turn on DHW disinfecting in boiler --]] https = require('ssl.https') json = require('json') ltn12 = require('ltn12') iDebug = true devIp = '192.168.x.xx' -- ems-esp.local devUrl = 'http://'..devIp..'/api/' function getData(iFunction)   if iDebug then log(devUrl..iFunction) end   res, code = https.request({       url = devUrl..iFunction,       method = 'GET'   })   if iDebug then       log(code, res)   end   return code, res end function setData(iFunction, iData)   if iDebug then log(devUrl..iFunction) end   res, code = https.request({       url = devUrl..iFunction,       method = 'POST',       headers = {["content-type"] = "application/json"},       data = iData       })   if iDebug then       log(code, res)   end   return code, res end -- get system info --getData('system') -- get boiler info - GET outputs current EMS device information in verbose --getData('boiler/info') -- get boiler values - GET outputs current EMS device information in short format --getData('boiler/values') -- get boiler - GET    same as values above --getData('boiler') -- get boiler commands - GET    lists the available command entities to call --getData('boiler/commands') -- get boiler entities -     GET    lists all enabled entities --getData('boiler/entities') -- get boiler dhw info --getData('boiler/dhw/info') -- get boiler entity heatingactive --getData('boiler/heatingactive') -- thermostaat streeftemperatuur --getData('thermostat/seltemp') -- dhw Laden --getData('thermostat/dhw/charge') setData('thermostat/dhw/charge', '{"value": true}') --curl -X POST http:///api/system/dhw/charge -H "Content-Type: application/json" -d '{"value": true}'
I also like to control the data with the setData function (last line). But i received an error 400. Whats wrong with my code?
Documentation can be found here: https://docs.emsesp.org/Commands/
You are missing Content-Length header for the POST request.
["Content-Length"] = #iData,
You should use json.encode instead of writing JSON manually to avoid potential errors.
(26.09.2025, 12:58)admin Wrote: You are missing Content-Length header for the POST request.
Like this (but with same error)?
setData('thermostat/dhw/charge', {value = true}) function setData(iFunction, iData)   if iDebug then log(devUrl..iFunction) end   res, code = https.request({       url = devUrl..iFunction,       method = 'POST',       headers = {["Content-Type"] = "application/json",                            ["Content-Length"] = #iData                           },       data = json.encode(iData)       })   if iDebug then       log(code, res)   end   return code, res end
Try this:
setData('thermostat/dhw/charge', {value = true}) function setData(iFunction, iData)   local data = json.encode(iData)   if iDebug then log(devUrl..iFunction) end   res, code = https.request({     url = devUrl..iFunction,     method = 'POST',     headers = {       ["Content-Type"] = "application/json",       ["Content-Length"] = #data     },     data = data   })   if iDebug then log(code, res) end   return code, res end
(26.09.2025, 13:13)admin Wrote: Try this:
Other error:
* arg: 1
  * string: closed
* arg: 2
  * nil
Are you sure that URL endpoint and parameters are correct?
(26.09.2025, 13:27)admin Wrote: Are you sure that URL endpoint and parameters are correct?
getData for that endpoint works and the result is:
* arg: 1
  * number: 200
* arg: 2
  * string: {"name":"charge","fullname":"dhw Laden","circuit":"dhw","bool":false,"index":0,"value":"uit","type":"boolean","readable":true,"writeable":true,"visible":true}
Send a request to http://<hostname>/api/<device>/commands to get a list of available commands. Do you have access token enabled in Security->Manage Users?
(26.09.2025, 13:39)admin Wrote: Send a request to http://<hostname>/api/<device>/commands to get a list of available commands. Do you have access token enabled in Security->Manage Users?
Access token is disabled
In the output i need the command:  ,"dhw[n].charge":"Laden"
Output:
{"info":"lijst van alle waardes","values":"list all values","commands":"lijst van alle commando's","entities":"lijst van alle entiteiten","[hc<n>.]boost":"boost mode","[hc<n>.]boosttime":"boost time","[hc<n>.]comforttemp":"Comforttemperatuur","[hc<n>.]control":"Afstandsbedieding","[hc<n>.]controlmode":"Comtrolemodus","[hc<n>.]cooloffdelay":"cooling off delay","[hc<n>.]coolondelay":"cooling on delay","[hc<n>.]coolstart":"cooling starttemp","[hc<n>.]cooltemp":"Temperatuur koelbedrijf","[hc<n>.]designtemp":"Ontwerptemperatuur","[hc<n>.]dewoffset":"Offset dauwpunt","[hc<n>.]dhwprio":"Prioriteit warm water","[hc<n>.]ecotemp":"Temperatuur eco","[hc<n>.]fastheatup":"Snel opwarmen","[hc<n>.]heatingtype":"Verwarmingstype","[hc<n>.]heatoffdelay":"heat-off delay","[hc<n>.]heatondelay":"heat-on delay","[hc<n>.]hpcooling":"WP koelbedrijf","[hc<n>.]hpminflowtemp":"Minimale aanvoertemperatuur WP","[hc<n>.]hpmode":"Modus warmtepomp","[hc<n>.]hpoperatingmode":"Bedrijfsmodus warmtepomp","[hc<n>.]instantstart":"instant start","[hc<n>.]intoffset":"Offset interne temperatuur","[hc<n>.]manualtemp":"Temperatuur handmatig","[hc<n>.]maxflowtemp":"Maximale aanvoertemperatuur","[hc<n>.]minflowtemp":"Minimale aanvoertemperatuur","[hc<n>.]mode":"Modus","[hc<n>.]nofrostmode":"Vorstbeveiligingsmodus","[hc<n>.]nofrosttemp":"Temperatuur vorstbeveiliging","[hc<n>.]noreducetemp":"Reduceermodus onderbreken onder","[hc<n>.]offsettemp":"Temperatuur offset","[hc<n>.]program":"Programma","[hc<n>.]redthreshold":"reduction threshold","[hc<n>.]reducemode":"Gereduceerde modus","[hc<n>.]reducetemp":"Onderste afschakeltemperatuur","[hc<n>.]remotehum":"room humidity from remote","[hc<n>.]remotetemp":"Ruimtetemperatuur van afstandsbediening","[hc<n>.]roominflfactor":"Factor ruimteinvloed","[hc<n>.]roominfluence":"Ruimteinvloed","[hc<n>.]roomtempdiff":"Verschiltemperatuur kamertemp","[hc<n>.]seltemp":"Streeftemperatuur kamer","[hc<n>.]solarinfl":"solar influence","[hc<n>.]summersetmode":"Instelling zomerbedrijf","[hc<n>.]summertemp":"Zomertemperatuur","[hc<n>.]switchonoptimization":"Inschakeloptimalisering","[hc<n>.]switchprogmode":"switch program mode","[hc<n>.]tempautotemp":"Streeftemperatuur automodus tijdelijk","absent":"absent","building":"Type gebouw","damping":"Demping buitentemperatuur","datetime":"Datum/Tijd","delayboiler":"Vertragingsoptie","dhw[n].charge":"Laden","dhw[n].chargeduration":"Laadtijd","dhw[n].circmode":"Modus circulatiepomp","dhw[n].dailyheating":"Dagelijks opwarmen","dhw[n].dailyheattime":"Tijd dagelijkse opwarming","dhw[n].disinfectday":"Desinfectiedag","dhw[n].disinfecting":"Desinfectie","dhw[n].disinfecttime":"Desinfectietijd","dhw[n].mode":"Modus","dhw[n].settemp":"Streeftemperatuut","dhw[n].settemplow":"Onderste streeftemperatuur","electricfactor":"Energiefactor electrisch","energycostratio":"Energiekostenratio","fossilefactor":"Energiefactor fossiele brandstof","hybridstrategy":"Hybride strategie","intoffset":"Offset interne temperatuur","minexttemp":"Min. buitentemperatuur","pvenabledhw":"Verhoging WW activeren","pvlowercool":"Verlagen koeling met PV activeren","pvraiseheat":"Verwarmen met PV activeren","solar":"solar","switchovertemp":"Schakeltemperatuur buitentemperatuur","tempdiffboiler":"Verschiltemperatuuroptie"}
Try sending true instead of {value = true}. If this does not help then you should ask this question here: https://github.com/emsesp/EMS-ESP32/discussions
Fyi: Theben has an Opentherm to KNX gateway and there is an Opentherm to EMS converter. I have this setup and it works very well.
(26.09.2025, 21:00)maxmp Wrote: Fyi: Theben has an Opentherm to KNX gateway and there is an Opentherm to EMS converter. I have this setup and it works very well.
Which Openterm to EMS converter do you use?
And can you control the DHW charge? (Extra warm water function)
Hi.
I have this gateway: https://www.robbshop.nl/nefit-ems-opentherm-converter
Regarding the DHW, i don't use this function, but i see its status.
Hi.
Thanks, and is it also possible to control this status?
(26.09.2025, 14:05)admin Wrote: Try sending true instead of {value = true}. If this does not help then you should ask this question here: https://github.com/emsesp/EMS-ESP32/discussions
If i try the same with Postman it works great, so why it doesnt work from the LM?
POST /api/thermostat/dhw/charge HTTP/1.1
Host: 192.168.x.x
Content-Length: 16
{"value": false}
Replace data = data with body = data in https.request({...}).
Thanks.. now it works
