06.11.2025, 05:08
Can LM read the physical address of KNX devices through the KNX IP routing mode?
PA
06.11.2025, 05:08
06.11.2025, 07:49
What exactly do you want to achieve? Functions like buslib.ping() should work over routing if "Pass ind. telegrams via IP Routing" is enabled.
25.11.2025, 02:42
(06.11.2025, 07:49)admin Wrote: What exactly do you want to achieve? Functions like buslib.ping() should work over routing if "Pass ind. telegrams via IP Routing" is enabled. I want to enable LM to read the physical address status of KNX devices under other KNX branches through IP routing. Is this possible?
25.11.2025, 07:31
Possible, you need to enable "Pass ind. telegrams via IP Routing" option in System config > Network > KNX connection.
