Unicode to ASCII conversion
Do you know how to convert Unicode to ASCII text? Or how to add Unicode text from variable(non group address) to visualization without conversion?
Visualization uses UTF-8 by default, as for dynamic text display you can use 255-byte string data type. It should work without any conversion.
(07.10.2015, 13:49)admin Wrote: Visualization uses UTF-8 by default, as for dynamic text display you can use 255-byte string data type. It should work without any conversion.
Where is this type?
Take a look at the attached screenshot, you should set the datatype for object and you don't have to specify it when calling grp.write() or grp.update().
(08.10.2015, 06:08)admin Wrote: Take a look at the attached screenshot, you should set the datatype for object and you don't have to specify it when calling grp.write() or grp.update().
It works Smile
Great job!
