01.04.2026, 09:24
Is it possible to display the RTC inside the LM in Visu?
Realtime Clock
01.04.2026, 09:24
02.04.2026, 11:04
Custom JavaScript example that adds current time near the close button. Header option must be enabled in General settings for this to work in Plan view.
Code: const el = document.querySelector('.navbar > .container-fluid > div:last-child')
09.04.2026, 13:07
After implementing the time via JS the main title is shifted to the left, can this be resolved?
09.04.2026, 13:20
Try this:
09.04.2026, 17:28
is possible provide Custom JavaScript for Tile View also? Alex
09.04.2026, 19:36
(09.04.2026, 17:28)AlexLV Wrote: Hi, It works in Tile view as well. If you want 24 hour format and date here is an example Code: const el = document.querySelector('.navbar > .container-fluid > div:last-child')
10.04.2026, 06:59
If you only want time in 24H format without seconds:
Code: span.textContent = date.toTimeString().substring(0, 5)
16.04.2026, 20:05
with dark theme the clock don't switch to white color
17.04.2026, 06:35
Add this before line 6 (span.style.right = '120%'):
Code: span.style.color = 'var(--visu-header-text-color)'
17.04.2026, 10:55
I use tile view ONLY and this idea with clock not working for me. Alex
17.04.2026, 11:04
It will only work in user view but not admin view.
Have you placed the code into the right place? It should be added to Visu admin > Top right menu (⋮) > Custom JavaScript.
17.04.2026, 11:33
Yes, code is in right place, but I checked with admin.
Now will check in user view |
