User Access Log on Vis
Hi, is there a way to display the user access logs in a frame on a vis page.
Only want to show user accounts and exclude ADMIN logins
Via .lp file:
<!DOCTYPE html> <html> <head>   <meta charset="UTF-8">   <link rel="stylesheet" href="/apps/css/bootstrap.css"> </head> <body> <table class="table table-striped"> <tr>   <th>Date/time</th>   <th>Login</th>   <th>Name</th>   <th>IP</th> </tr> <? require('apps') items = db:getall([[   SELECT user_logs.*, users.name   FROM user_logs   JOIN users ON user_logs.login=users.login   ORDER BY user_logs.id DESC   LIMIT 50 ]]) for _, item in ipairs(items) do   cls = toboolean(item.failed) and 'danger' or 'success'   datetime = os.date('%Y.%m.%d %H:%M:%S', item.created) ?> <tr class="<?=cls?>">   <td><?=datetime?></td>   <td><?=escape(item.login)?></td>   <td><?=escape(item.name)?></td>   <td><?=escape(item.ip)?></td> </tr> <? end ?> </table> </body> </html>
(06.05.2022, 08:26)admin Wrote: Via .lp file:
 Many thanks for your help
Hello
how does the full code looks like?
Best Regards,
It is the full code (:
(07.05.2022, 18:22)Erwin van der Zwart Wrote: It is the full code (:
Aha
Seems I miss how to use it Smile
should I have something like this at the beginning or its done in another way
dst = '/www/user/accesslog.lp'
io.writefile(dst, [[..... accesss log code....
Best Regards,
Well this code is enabling you to automatically write it to a file on the FTP server, but you could have also just manually upload the code as a .lp file to the FTP server...
Good evening,
I want open again this thread, I have done all but the table it is empty. My will it is to get the access to the LM as user. Is it possible?
Best regards Cristian Grassi
It will only show logins from existing non-admin users. Do you want to display admin logins too?
(30.06.2026, 16:56)admin Wrote: It will only show logins from existing non-admin users. Do you want to display admin logins too?
I need to log any user who has opened mosaic or visu or Cloud access. Is it possible?
