User Access Log on Vis
Hi, is there a way to display the user access logs in a frame on a vis page.
Only want to show user accounts and exclude ADMIN logins
Via .lp file:
<!DOCTYPE html> <html> <head>   <meta charset="UTF-8">   <link rel="stylesheet" href="/apps/css/bootstrap.css"> </head> <body> <table class="table table-striped"> <tr>   <th>Date/time</th>   <th>Login</th>   <th>Name</th>   <th>IP</th> </tr> <? require('apps') items = db:getall([[   SELECT user_logs.*, users.name   FROM user_logs   JOIN users ON user_logs.login=users.login   ORDER BY user_logs.id DESC   LIMIT 50 ]]) for _, item in ipairs(items) do   cls = toboolean(item.failed) and 'danger' or 'success'   datetime = os.date('%Y.%m.%d %H:%M:%S', item.created) ?> <tr class="<?=cls?>">   <td><?=datetime?></td>   <td><?=escape(item.login)?></td>   <td><?=escape(item.name)?></td>   <td><?=escape(item.ip)?></td> </tr> <? end ?> </table> </body> </html>
(06.05.2022, 08:26)admin Wrote: Via .lp file:
 Many thanks for your help
Hello
how does the full code looks like?
Best Regards,
It is the full code (:
(07.05.2022, 18:22)Erwin van der Zwart Wrote: It is the full code (:
Aha
Seems I miss how to use it Smile
should I have something like this at the beginning or its done in another way
dst = '/www/user/accesslog.lp'
io.writefile(dst, [[..... accesss log code....
Best Regards,
Well this code is enabling you to automatically write it to a file on the FTP server, but you could have also just manually upload the code as a .lp file to the FTP server...
