Hi, is there a way to display the user access logs in a frame on a vis page.
Only want to show user accounts and exclude ADMIN logins
User Access Log on Vis
06.05.2022, 08:26
Via .lp file:
Code: <!DOCTYPE html>
<html>
<head>
<meta charset="UTF-8">
<link rel="stylesheet" href="/apps/css/bootstrap.css">
</head>
<body>
<table class="table table-striped">
<tr>
<th>Date/time</th>
<th>Login</th>
<th>Name</th>
<th>IP</th>
</tr>
require('apps')
items = db:getall([[
SELECT user_logs.*, users.name
FROM user_logs
JOIN users ON user_logs.login=users.login
ORDER BY user_logs.id DESC
LIMIT 50
for _, item in ipairs(items) do
cls = toboolean(item.failed) and 'danger' or 'success'
datetime = os.date('%Y.%m.%d %H:%M:%S', item.created)
<tr class="<?=cls?>">
<td><?=datetime?></td>
<td><?=escape(item.login)?></td>
<td><?=escape(item.name)?></td>
<td><?=escape(item.ip)?></td>
</tr>
<? end ?>
</table>
</body>
</html>
06.05.2022, 13:43
(06.05.2022, 08:26)admin Wrote: Via .lp file:Many thanks for your help
07.05.2022, 18:22
It is the full code (:
08.05.2022, 15:47
(07.05.2022, 18:22)Erwin van der Zwart Wrote: It is the full code (: Aha Seems I miss how to use it ![]() should I have something like this at the beginning or its done in another way dst = '/www/user/accesslog.lp' io.writefile(dst, [[..... accesss log code.... ]])
Best Regards,
09.05.2022, 06:49
(This post was last modified: 09.05.2022, 06:50 by Erwin van der Zwart.)
Well this code is enabling you to automatically write it to a file on the FTP server, but you could have also just manually upload the code as a .lp file to the FTP server...
30.06.2026, 12:56
Good evening,
I want open again this thread, I have done all but the table it is empty. My will it is to get the access to the LM as user. Is it possible? Best regards Cristian Grassi
30.06.2026, 16:56
It will only show logins from existing non-admin users. Do you want to display admin logins too?
30.06.2026, 17:13
