writing to a bit object
 If I do grp.response('1/1/1',1,dt.bool)  the value is not always written to the bus,  unlike when I write grp.response('1/1/1',true,dt.bool) it is always written. Specifying the data type makes no difference.
As a workaround I have to do this
function tobool( val )     if ( val == nil || val == false || val == 0 || val == "0" || val == "false" ) then return false end     return true end        local receivedcommand = string.split(response[2],' ')        local sw= tobool(dim[1])        grp.response('11/1/14',sw,dt.bool)
That way I get the string into a number which is then converted to an boolean,  which seems a lot.
Note I have noticed this behavior in all firmware releases and is the same for grp.write.
Thanks,
Roger
The value is already converted using toboolean function (http://openrb.com/docs/lua.htm#toboolean). I suspect the problem is somewhere else in your code, have you tried logging the value that you're passing to grp.write/grp.reponse? Also, your example is not correct Lua code.
Hi Admin,
Am sure. My point it's a pain to convert to boolean, would be simpler when grp.write, response etc could consistently accept a number 0 or 1.
Thanks,
Roger
It's already converted to boolean internally. It will write false if passed value is either boolean false, zero (number) or an empty string or a string '0'. Otherwise it will write true, unless you pass nil, then nothing will happen. Have you tried logging the result of grp.write?
