Set value of object with curl
I would like to set an object value from another machine.
I can do this manually from a web browser using this url:
http://remoteusr:remotepasswd@192.168.0.40:80/scada-remote?m=json&r=grp&fn=write&alias=15/0/87&value=1
When I use curl on the other machine as follows:
curl -0 -i -H "Accept: application/json" -H "Content-Type: application/json" -X POST http://remoteusr:remotepasswd@192.168.0.40:80/scada-remote?m=json&fn=write&alias=15/0/87&value=1
the following is returned:
1234567891011121314
[1] 6322 [2] 6323 [3] 6324 [4] 6325 [2]   Klaar                   r=grp [3]-  Klaar                   fn=write [emm@bilbo 23]$ HTTP/1.1 200 OK Server: nginx Date: Mon, 11 Sep 2017 09:56:56 GMT Content-Type: text/plain Content-Length: 31 Connection: close Invalid parameter "r" (request)
The object value is not set.
I'm not particularly familiar with curl and there are a million options to it, so can anyone help me out?
I've found the solution by using this command:
curl -0 -i -H "Accept: application/json" -H "Content-Type: application/json" --data "m=json&r=grp&fn=write&alias=15/&value=0"  http://remoteusr:remotepasswd@192.168.0.40:80/scada-remote
Or just escape the whole url with ""
(11.09.2017, 13:32)admin Wrote: Or just escape the whole url with ""
That also works indeed!
