Link to download backup
I would like to create a cron script on a separate machine to download a Backup regularly. Does someone know the link or json to do this?
For current stable FW:
http://admin:PASSWORD@IP/cgi-bin/scada/general/utilities-backup.cgi
For upcoming FW:
http://admin:PASSWORD@IP/scada-main/general/backup
I have a simular question, how to do an automatic backup daily/ weekly.
The example script does not seem to work?
Double check that you have set correct password and IP. You can open this link in browser and download dialog should appear.
All I did was add http://admin:PASSWORD@IP/cgi-bin/scada/general/utilities-backup.cgi to a cron job on a separate linux box (could even be a raspi). I use a simple backup rotating script to have a daily/weekly/monthly backup on disk. Works like a charm.
(19.01.2016, 09:31)managementboy Wrote: All I did was add http://admin:PASSWORD@IP/cgi-bin/scada/general/utilities-backup.cgi to a cron job on a separate linux box (could even be a raspi). I use a simple backup rotating script to have a daily/weekly/monthly backup on disk. Works like a charm.
Thanks, but I was looking for a solution from the logic machine based on this script
http://openrb.com/e-mail-backup-file-onc...h-from-lm/
Just create a planned script and set the interval to week/month by cron, past my script in it, and adjust your gmail settings.
Due to new security settings from gmail you have to activate a setting in your gmail account.  Login to google with your account and go to this url:
https://www.google.com/settings/security/lesssecureapps and make sure it's enabled otherwise the controller will be blocked for sending e-mail.
Good luck!
(20.01.2016, 19:52)npinguin Wrote: Thanks, but I was looking for a solution from the logic machine based on this script
my solution has the advantage, that the image does not leave my network at any time...
