13.01.2016, 12:56
I would like to create a cron script on a separate machine to download a Backup regularly. Does someone know the link or json to do this?
Link to download backup
13.01.2016, 12:56
13.01.2016, 13:11
For current stable FW:
http://admin:PASSWORD@IP/cgi-bin/scada/general/utilities-backup.cgi For upcoming FW: http://admin:PASSWORD@IP/scada-main/general/backup
18.01.2016, 17:45
I have a simular question, how to do an automatic backup daily/ weekly.
The example script does not seem to work? Thanks
19.01.2016, 08:30
Double check that you have set correct password and IP. You can open this link in browser and download dialog should appear.
19.01.2016, 09:31
All I did was add http://admin:PASSWORD@IP/cgi-bin/scada/general/utilities-backup.cgi to a cron job on a separate linux box (could even be a raspi). I use a simple backup rotating script to have a daily/weekly/monthly backup on disk. Works like a charm.
20.01.2016, 19:52
(19.01.2016, 09:31)managementboy Wrote: All I did was add http://admin:PASSWORD@IP/cgi-bin/scada/general/utilities-backup.cgi to a cron job on a separate linux box (could even be a raspi). I use a simple backup rotating script to have a daily/weekly/monthly backup on disk. Works like a charm. Thanks, but I was looking for a solution from the logic machine based on this script http://openrb.com/e-mail-backup-file-onc...h-from-lm/
20.01.2016, 23:08
Just create a planned script and set the interval to week/month by cron, past my script in it, and adjust your gmail settings. Due to new security settings from gmail you have to activate a setting in your gmail account. Login to google with your account and go to this url: https://www.google.com/settings/security/lesssecureapps and make sure it's enabled otherwise the controller will be blocked for sending e-mail. Good luck! BR, Erwin
22.01.2016, 15:28
(20.01.2016, 19:52)npinguin Wrote: Thanks, but I was looking for a solution from the logic machine based on this script my solution has the advantage, that the image does not leave my network at any time... |
