Modbus profile with SunSpec Data Types
Hi all,
I need to create a Modbus profile for a PV inverter with Sunspec Data Types. They are documented at https://www.sma.de/fileadmin/content/lan...-en-15.pdf on page 13-14. The most registers have the dt int or uint and can be easily integrated into the Modbus profile. But I also need some registers with data types that are not in the LM Modbus profile description like acc32, bitfield16, enum16 or string. I already read that the string format is not supported in profile, so my question is, if the other three data types can be integrated?
For example there is a register called "Battery Type" with dt enum16. Then there are defined types for values from 0 to 10 like 0: Unknown, 1: Lithium-Ion, ...
Can I set the register in the Modbus profile as dt uint16 and write these types under value_custom? Same question applies to the dt bitfield16, because there are also costum values.
I can't do a RTU read test right now so I'm thankful for any help.
Best Regards
(03.07.2018, 12:30)winam Wrote: For example there is a register called "Battery Type" with dt enum16. Then there are defined types for values from 0 to 10 like 0: Unknown, 1: Lithium-Ion, ...
Hi, I think that it is the best way
try to do like this
{      "name": "Mode",      "bus_datatype": "uint8",      "datatype": "int16",      "type": "register",      "address": 3,      "writable": 1,      "Value_custom": {        "0": "Auto",        "1": "Heat",        "2": "Fan",        "3": "Cool",        "4": "Dry"      }    },
(03.07.2018, 12:30)winamp Wrote:  Same question applies to the dt bitfield16, because there are also costum values.
here you need valuebitmask
for bitfield16 exaple:
{      "name": "bitfield16 bit 0",      "bus_datatype": "bool",      "type": "register",      "datatype": "uint16",      "address": 50002,       "value_bitmask": "1",      "value_custom": {        "0": "no err",        "1": "err"      }    },     {      "name": "bitfield16 bit 1",      "bus_datatype": "bool",      "type": "register",      "datatype": "uint16",      "address": 50002,       "value_bitmask": "2",      "value_custom": {        "0": "no err",        "1": "err"      }    },     {      "name": "bitfield16 bit 2",       "bus_datatype": "bool",       "type": "register",      "datatype": "uint16",       "address": 50002,       "value_bitmask": "4",      "value_custom": {      "0": "no err",      "1": "err"      }    },
value bitmask = 2^N
N - bit number (from 0 to 15)
for bitfield32 example:
{      "name": "bitfield32 bit 0",      "bus_datatype": "bool",      "type": "register",      "datatype": "uint16",      "read_swap": "b",      "address": 50002,       "value_bitmask": "1",      "value_custom": {        "0": "no err",        "1": "err"      }    },     {      "name": "bitfield32 bit 1",      "bus_datatype": "bool",      "type": "register",      "datatype": "uint16",      "read_swap": "b",      "address": 50002,       "value_bitmask": "2",      "value_custom": {        "0": "no err",        "1": "err"      }    },
there is new feald - "read_swap"
read_swap
 Boolean/String
Swap byte/word order during conversion (endianness). Default value is word (2-byte) swap.
Possible string values:
n
 (no swap),
w
 (word swap),
b
 (byte swap),
bw
 (byte and word swap)
Example:
no swap: 0xABCD
word swap: 0xCDAB
byte swap: 0xBADC
byte and word swap: 0xDCBA
