03.07.2018, 12:30
Hi all,
I need to create a Modbus profile for a PV inverter with Sunspec Data Types. They are documented at https://www.sma.de/fileadmin/content/lan...-en-15.pdf on page 13-14. The most registers have the dt int or uint and can be easily integrated into the Modbus profile. But I also need some registers with data types that are not in the LM Modbus profile description like acc32, bitfield16, enum16 or string. I already read that the string format is not supported in profile, so my question is, if the other three data types can be integrated?
For example there is a register called "Battery Type" with dt enum16. Then there are defined types for values from 0 to 10 like 0: Unknown, 1: Lithium-Ion, ...
Can I set the register in the Modbus profile as dt uint16 and write these types under value_custom? Same question applies to the dt bitfield16, because there are also costum values.
I can't do a RTU read test right now so I'm thankful for any help.
Best Regards
Best Regards
