17.02.2016, 11:26
I want to copy objects from one LM to the other. Is there any possibility?
Copying objects from LMx to LMx
17.02.2016, 11:26
18.02.2016, 08:39
18.02.2016, 09:13
Is there option to export objects to esf file from LM/HL?
18.02.2016, 10:07
(18.02.2016, 08:39)gtsamis Wrote:(17.02.2016, 11:26)buuuudzik Wrote: Hello, But when LM1 has other firmware version than LM2? E.g. doing back-up before upgrading firmware.
18.02.2016, 13:03
(18.02.2016, 10:07)buuuudzik Wrote:You can use utilities -> import neighbours button in lm2, in lm 1 you must activate remote services and mark Group adresses chekbox "export" in objects table. lm1 and lm2 must be at the same local network(18.02.2016, 08:39)gtsamis Wrote:(17.02.2016, 11:26)buuuudzik Wrote: Hello,
18.02.2016, 14:46
(18.02.2016, 13:03)AEK Wrote:(18.02.2016, 10:07)buuuudzik Wrote:You can use utilities -> import neighbours button in lm2, in lm 1 you must activate remote services and mark Group adresses chekbox "export" in objects table. lm1 and lm2 must be at the same local network(18.02.2016, 08:39)gtsamis Wrote:(17.02.2016, 11:26)buuuudzik Wrote: Hello, It is very good but it is from old firmware
20.02.2016, 08:08
(18.02.2016, 14:46)buuuudzik Wrote:(18.02.2016, 13:03)AEK Wrote:(18.02.2016, 10:07)buuuudzik Wrote:You can use utilities -> import neighbours button in lm2, in lm 1 you must activate remote services and mark Group adresses chekbox "export" in objects table. lm1 and lm2 must be at the same local network(18.02.2016, 08:39)gtsamis Wrote:(17.02.2016, 11:26)buuuudzik Wrote: Hello, Take a backup, update FW and use import neighbours.
20.02.2016, 13:42
(20.02.2016, 08:08)gtsamis Wrote:(18.02.2016, 14:46)buuuudzik Wrote:(18.02.2016, 13:03)AEK Wrote:(18.02.2016, 10:07)buuuudzik Wrote:You can use utilities -> import neighbours button in lm2, in lm 1 you must activate remote services and mark Group adresses chekbox "export" in objects table. lm1 and lm2 must be at the same local network(18.02.2016, 08:39)gtsamis Wrote: If your other LM is empty you can use backup/restore. I don't have an options "import neighbours" on my LM but thanks for your reply.
22.02.2016, 07:07
So, do you want to import objects from LM with older firmware to a newer one or the other way round?
22.02.2016, 08:25
(22.02.2016, 07:07)admin Wrote: So, do you want to import objects from LM with older firmware to a newer one or the other way round? Yes, because sometimes there are some upgrades and it will be good if I can save actul list of objects with their settings. The best thing will be when I can export and import the list of object. The same situation will be good with Trends and Schedulers but I know that you are planning some changes in the mechanism of Trends and they will be incompatible with the older firmware so I understand it. |
