Script restart after powerloss: ERWIN
(14.10.2018, 17:37)Erwin van der Zwart Wrote: Hi,
You make things more complex then needed..
On the (event) object settings you can enable “Read during startup”
Make sure the read flag is enabled in the ETS for this object.
When the controller reboots it will send a read request and the object will get the correct value from the installation and the event script will be executed and the output result should be as wanted.
Hi Erwin
You mean *Execute on group read:* ?
Because I did not find anything that is called “Read during startup”
How can I do it less complicated ?
BR Adam
RE: Script restart after powerloss: ERWIN - by adigornik - 15.10.2018, 10:57
