Weather service not working anymore?
#29
Thank you Admin
If someone is interested in then there's yrno script below (warning: uses obsolete API)
Function minmax_temp_tomorrow returns lowest and highest temperature for tomorrow. The script is simple and ignores time shift.
require('socket.http') forecast = {} function parsetag(parser, tag, attributes)  if tag == 'time' then    table.insert(forecast, {})    forecast[ #forecast ].from=attributes.from    forecast[ #forecast ].to=attributes.to    forecast[ #forecast ].period=attributes.period  elseif tag == 'symbol' then    forecast[ #forecast ].symbol = attributes.name  elseif tag == 'precipitation' then    forecast[ #forecast ].precipitation = attributes.value  elseif tag == 'windDirection' then    forecast[ #forecast ].wind_direction = attributes.code  elseif tag == 'windSpeed' then    forecast[ #forecast ].wind_speed = attributes.mps  elseif tag == 'temperature' then    forecast[ #forecast ].temperature = attributes.value  elseif tag == 'pressure' then    forecast[ #forecast ].pressure = attributes.value  end end function yrno_fetch()  local url = 'http://www.yr.no/place/Czech_Republic/Prague/Prague/varsel.xml'  local data, err = socket.http.request(url)  if data then    require('lxp').new({      StartElement = parsetag    }):parse(data)          else    alert('Fetch failed: ' .. tostring(err))  end end function minmax_temp_tomorrow()  local ld_minTemp  local ld_maxTemp  local next_day={}  yrno_fetch()  if (not forecast) then    return  end  local ll_tomorrow=os.time()+24*3600 -- tomorrow as long  local lt_tomorrow= os.date("*t",ll_tomorrow) -- tomorrow as table for use if forecast_write  --gets date of tomorrow  local ls_match=os.date("%Y--%m--%d",ll_tomorrow)   for index, value in ipairs(forecast) do    if (value.from:match("^"..ls_match)) then      local ld_temp=tonumber(value.temperature)      if (ld_minTemp == nil) then        ld_minTemp=ld_temp      end      if (ld_maxTemp == nil) then        ld_maxTemp=ld_temp      end      if (ld_temp<ld_minTemp or index==1) then        ld_minTemp=ld_temp      end      if (ld_temp>ld_maxTemp or index==1) then        ld_maxTemp=ld_temp      end    end end   return ld_minTemp,ld_maxTemp,lt_tomorrow end
RE: Weather service not working anymore? - by Thomas - 08.01.2019, 16:21
