event based scripts continue to run even when they are disabled
Create virtual object.  Add the script below and run it.  Now wait until logs the first time.  Then disable the script.  It will continue to run in the background even though it should be disabled.    I would expect when you hit disabled it should kill off any running threads of the script.
thx
Roger
mac="c0:48:e6:ee:d1:2f" function sendWOL()  --call the WOL  local WOL = function(target)    local dest_ip="255.255.255.255"    local port=9    local socket = require("socket")    local udpwol = assert(socket.udp())    udpwol:setoption('broadcast', true)    clean_target = string.gsub(target,":","")    clean_target = string.gsub(clean_target,"-","")    hex_target = lmcore.hextostr(clean_target)    payload = lmcore.hextostr("FFFFFFFFFFFF")    for i=1,16 do      payload = payload .. hex_target    end    assert(udpwol:sendto(payload, dest_ip, port))  end  WOL(mac)  WOL(mac)  WOL(mac)  WOL(mac)  WOL(mac)  WOL(mac)  sleep(1)  WOL(mac)  WOL(mac)  WOL(mac)  WOL(mac)  WOL(mac)  WOL(mac) end while true do  log("running")  sleep(150)  sendWOL()  log("sent wol") end
event based scripts continue to run even when they are disabled - by rocfusion - 26.01.2019, 01:58
