Sync 2 Objects
Trying to find a way of synchronising two object, 1 master the other slave.
So that the slave always follows the master 1/1/1
So is a scene set object 1/1/1 to dim to 50% over 8seconds then object 1/1/110 follows the same level and ramprate.
Yes could put the same groups in a scene, but we have 20 objects already in a scene and don't want to add the slave objects because it would confuse the user. and would also have to rely on the user setting the same parameters in both objects.
We are using a C-Bus device hat wont allow the same object to be used in both channels, hence we want to map one channel to the other.
Any help wold be appreciated.
Sync 2 Objects - by sjfp - 02.05.2019, 11:54
RE: Sync 2 Objects - by Daniel - 02.05.2019, 11:57
RE: Sync 2 Objects - by sjfp - 02.05.2019, 14:59
RE: Sync 2 Objects - by Daniel - 03.05.2019, 07:44
