[OLD] LogicMachine firmware 2019.10
#22
(25.11.2019, 07:35)admin Wrote: This means that connection is working fine.
Next add some logging to group event callback:
  function publishvalue(event)     -- message from us or client is not connected     if event.sender == 'mq' or not mclientfd then       return     end     local addr = event.dst     local dpt = datatypes[ addr ]     local topic = object_to_mqtt[ addr ]     -- unknown object     if not dpt or not topic then       return     end     local value = busdatatype.decode(event.datahex, dpt)     if value ~= nil then       if type(value) == 'boolean' then         value = value and 1 or 0       end       log('publish', mclient:publish(topic, tostring(value)) )     else       log('failed to decode data', event.datahex, dpt)     end   end
Don´t log anything when I change value of 37/3/1 and in the script i have:
object_to_mqtt = {     ['37/3/1'] = 'SEND1',     ['37/3/2'] = 'SEND2',  --SEND 1 and SEND 2 are object to mqtt commands   }
RE: [PRE-RELEASE 1] LogicMachine firmware 2019.10 - by DGrandes - 25.11.2019, 09:05
