12.12.2019, 21:22
Hopefully someone can help me with the following "problem".
I would like to use the PID script to control the temperature in one of the bedrooms.
The temperature have to be set to 18 degrees... if under setpoint set groupadress ON, if setpoint reached set groupadress OFF.
I saw this example script, but the setpoint must not be an groupadress but a fixed value..
This script gives the following error:
Resident script:3: attempt to index global 'PID' (a nil value)
stack traceback:
So I think I made a mistake in the setpoint notation... can somebody help me?
Best,
Jos
- -- init pid algorithm
- if not p then
- p = PID:init({
- current = '1/1/1',
- setpoint = '18',
- output = '1/1/3'
- end
- -- run algorithm
- p:run()
stack traceback:
Best,
Jos
