Blinds Control - Multiple Socket Connections Per Script
Hi Erwin,
That still didn't work either .. the first command executes however the second one does not.
Even in a really simple example, the second command doesn't execute with the added \r.  For example
function sendCommand(command)   local socket = require("socket").tcp()   data, err = socket:connect('192.168.1.200', 4999)   data, err = socket:send(command .. '\x0D\x0A' .. '\r')  end sendCommand('0113U');  os.sleep(1) log('Sleep 1') sendCommand( '0113S');  log('Sleep 2')
If I split this into two separate scripts and run the first one, then the second one a second later the commands execute as expected - however if I call sendCommand twice from the same script, the second calls fails (and I never see 'Sleep 2' in the logs.
Any idea why this would be happening?
Kind Regards
James
RE: Blinds Control - Multiple Socket Connections Per Script - by jamesng - 09.02.2020, 09:14
