Telegram bot API
(10.02.2020, 08:22)admin Wrote: You are trying to do a POST request, try GET like this:
stat, code, hdrs = request(telegram_url .. data_str)
If this still does not work then the only solution is to do firmware upgrade to 2019 RC1.
Hi!
I used in my message "\n" to go new line.
Now I receive only first line:
if grp.getvalue('9/2/7')== true then txtstate='On' else txtstate='Off' end       txtmessage = txtmessage .. ('Primario: ' .. txtstate .. '\n')    if grp.getvalue('9/2/1')== true then txtstate='On' else txtstate='Off' end       txtmessage = txtmessage .. ('Caldaia: ' .. txtstate .. '\n') local stat, code, hdrs = request(telegram_url .. txtmessage)
Message on log is ok, message on telegram is:
"Primario: On" not else.
Telegram bot API - by Domoticatorino - 18.10.2016, 11:49
RE: Telegram bot API - by Erwin van der Zwart - 18.10.2016, 15:35
RE: Telegram bot API - by Domoticatorino - 18.10.2016, 21:23
RE: Telegram bot API - by Erwin van der Zwart - 19.10.2016, 08:36
RE: Telegram bot API - by Domoticatorino - 19.10.2016, 09:22
RE: Telegram bot API - by Erwin van der Zwart - 19.10.2016, 09:33
RE: Telegram bot API - by Domoticatorino - 27.10.2016, 12:05
RE: Telegram bot API - by admin - 27.10.2016, 13:05
RE: Telegram bot API - by Domoticatorino - 27.10.2016, 21:23
RE: Telegram bot API - by Domoticatorino - 15.11.2016, 12:20
RE: Telegram bot API - by DGrandes - 05.09.2018, 16:19
RE: Telegram bot API - by baggins - 09.02.2020, 22:52
RE: Telegram bot API - by admin - 10.02.2020, 06:40
RE: Telegram bot API - by baggins - 10.02.2020, 07:53
RE: Telegram bot API - by admin - 10.02.2020, 08:22
RE: Telegram bot API - by baggins - 10.02.2020, 09:08
RE: Telegram bot API - by Dario - 19.03.2020, 18:43
RE: Telegram bot API - by admin - 19.03.2020, 18:48
RE: Telegram bot API - by Dario - 20.03.2020, 09:48
RE: Telegram bot API - by JRP - 12.05.2020, 18:06
