Password for keypad!
I created this a few years ago in custom JS, works a lot faster and smoother..
1) Create 10 buttons and give it a custom class pin0 to pin9
2) Create 1 button with custom class "pinback"
3) Create 1 button with custom class "pincancel"
4) Create a text label with custom cllass "entered"
5) Create a 4 byte signed integer object (in this sample "63/7/254")
6) Add this script to custom JS :
$(function(){     // Reset pin on visu load   var pin = ""   var enteredpin = ""   var maxlenght = 8   $(".entered").text(pin);     function Pin(pinnumber) {     if (pin.length < maxlenght){       pin = pin + String(pinnumber);       enteredpin = enteredpin + '*'       $(".entered").text(enteredpin);       if (pin.length == maxlenght){           Pin_Send();       }     }   }        function Pin_Back() {     if (pin.length > 1){       pin = pin.substring(0, pin.length - 1);       enteredpin = enteredpin.substring(0, enteredpin.length - 1);       $(".entered").text(enteredpin);     } else {       Pin_Cancel();     }   }   function Pin_Cancel() {     pin = "";     enteredpin = "";     $(".entered").text(enteredpin);   }   function Pin_Send() {     if (pin.length > 0 && pin.length < (maxlenght + 1) ){       grp.write('63/7/254', pin);       Pin_Cancel();     } else {       Pin_Cancel();     }   }    $( ".pin1" ).click(function() {     Pin(1);   });   $( ".pin2" ).click(function() {     Pin(2);   });   $( ".pin3" ).click(function() {     Pin(3);   });   $( ".pin4" ).click(function() {     Pin(4);   });   $( ".pin5" ).click(function() {     Pin(5);   });   $( ".pin6" ).click(function() {     Pin(6);   });   $( ".pin7" ).click(function() {     Pin(7);   });   $( ".pin8" ).click(function() {     Pin(8);   });   $( ".pin9" ).click(function() {     Pin(9);   });   $( ".pin0" ).click(function() {     Pin(0);   });   $( ".pincancel" ).click(function() {     Pin_Cancel();   });   $( ".pinback" ).click(function() {     Pin_Back();   }); });
You can attached a LUA script to 63/7/254 to compare the enter code with your desired code and if it match execute the action..
Password for keypad! - by phongvucba - 11.06.2020, 08:54
RE: Password for keypad! - by admin - 11.06.2020, 08:54
RE: Password for keypad! - by phongvucba - 11.06.2020, 15:26
RE: Password for keypad! - by Daniel - 11.06.2020, 15:37
RE: Password for keypad! - by phongvucba - 11.06.2020, 16:06
RE: Password for keypad! - by Daniel - 12.06.2020, 07:37
RE: Password for keypad! - by Erwin van der Zwart - 12.06.2020, 11:09
RE: Password for keypad! - by phongvucba - 13.06.2020, 02:45
RE: Password for keypad! - by Daniel - 15.06.2020, 08:06
RE: Password for keypad! - by phongvucba - 15.06.2020, 16:59
