RS485
Try a connecting to a different port,  I found that with a LM4 only one port was working
I created a function and stored this in the Common scripts.
function sendSOMFY(command)  require('serial')  port = serial.open('/dev/RS485-3', { baudrate = 4800, parity = 'odd', duplex = 'half', databits = 8, stopbits = 1 })  port:flush()  port:write(command)  port:close()  sleep(0.1) end
Also the codes you use, there are different versions of the Somfy command generator. Depending on what type of motor being used each version may generate a different RS485 command. Also be sure your selecting the right addressing scheme, ie individual or group which is determine by how that motor has been programmed.
thx
Roger
RS485 - by Girish - 05.08.2016, 10:11
RE: RS485 - by rocfusion - 05.08.2016, 13:50
RE: RS485 - by Girish - 06.08.2016, 05:08
RE: RS485 - by buuuudzik - 27.08.2016, 14:57
