Telnet communication with Biamp Tesira
Try this:
local host, port = "192.168.2.60", 23 local socket = require("socket") local tcp = assert(socket.tcp()) tcp:connect(host, port) tcp:settimeout(0.5) --Set command command = string.char(0xFF,0xFD,0x01) -- Do Echo -- Write command tcp:send(command .. '\r') --or try Write command --tcp:send(command) --Get Reply local s, status, partial = tcp:receive()   --Check if reply has a value if s then     --Do your action(s) with replies     if s == string.char(0xFF,0xFC,0x01) then      log('Wont Echo')     end     loghex(s) end tcp:close()
RE: Telnet communication with Biamp Tesira - by Erwin van der Zwart - 29.10.2020, 14:21
