Email sending do not work
#24
This can possibly be some firewall/router issue. Try this script and post what you get in Logs tab:
require('socket') ssl = require('ssl') s = socket.tcp() s:settimeout(5) res, err = s:connect('smtp.gmail.com', 465) log('connect', res, err) if res then   res, err = ssl.wrap(s, { mode = 'client', protocol = 'tlsv12' })   log('wrap', res, err)   if res then     s = res     s:settimeout(5)     res, err = s:dohandshake()     log('handshake', res, err)     if res then       res, err = s:receive('*l')       log('receive', res, err)     end   end end s:close()
You can also replace 'smtp.gmail.com', 465 with another host/port with SSL support to test the connection.
Email sending do not work - by Tue - 20.08.2020, 09:34
RE: Email sending do not work - by admin - 20.08.2020, 09:35
RE: Email sending do not work - by Tue - 20.08.2020, 09:38
RE: Email sending do not work - by admin - 20.08.2020, 09:38
RE: Email sending do not work - by Tue - 20.08.2020, 09:41
RE: Email sending do not work - by admin - 20.08.2020, 09:42
RE: Email sending do not work - by Tue - 20.08.2020, 09:44
RE: Email sending do not work - by admin - 20.08.2020, 09:49
RE: Email sending do not work - by Tue - 20.08.2020, 09:51
RE: Email sending do not work - by Tue - 20.08.2020, 09:55
RE: Email sending do not work - by Daniel - 20.08.2020, 09:58
RE: Email sending do not work - by Tue - 20.08.2020, 09:58
RE: Email sending do not work - by Daniel - 20.08.2020, 10:04
RE: Email sending do not work - by Tue - 20.08.2020, 10:19
RE: Email sending do not work - by admin - 20.08.2020, 10:29
RE: Email sending do not work - by Tue - 20.08.2020, 10:37
RE: Email sending do not work - by Ibrahim - 20.11.2020, 15:50
RE: Email sending do not work - by Daniel - 23.11.2020, 09:55
RE: Email sending do not work - by Ibrahim - 23.11.2020, 15:44
RE: Email sending do not work - by Ibrahim - 26.11.2020, 08:04
RE: Email sending do not work - by admin - 27.11.2020, 08:27
RE: Email sending do not work - by Ibrahim - 27.11.2020, 12:39
RE: Email sending do not work - by admin - 27.11.2020, 14:43
RE: Email sending do not work - by Ibrahim - 27.11.2020, 20:13
RE: Email sending do not work - by admin - 30.11.2020, 07:35
RE: Email sending do not work - by BrentW - 24.03.2021, 00:15
RE: Email sending do not work - by admin - 24.03.2021, 09:22
RE: Email sending do not work - by BrentW - 25.03.2021, 02:32
RE: Email sending do not work - by admin - 25.03.2021, 07:14
RE: Email sending do not work - by BrentW - 06.04.2021, 04:14
RE: Email sending do not work - by admin - 06.04.2021, 05:48
