03.10.2016, 09:08
(03.10.2016, 07:11)admin Wrote: The only solution that I see is that you create another object for each one you want to log and then filter the input value in an event script.Thank you for the answer, unfortunately for object logging it doesn't seem optimized solution, probably i will switch to general logging where i can filter what and when to log it.
Add this to Common functions:
Code:function checkupdate(sendto, mindelta) -- event value local newvalue = event.getvalue() -- current object value local curvalue = grp.getvalue(sendto) -- absolute delta between event and current value local valdelta = math.abs(curvalue - newvalue) -- send if delta value is large enough if valdelta >= mindelta then grp.update(sendto, newvalue) end end
Create an event script for each object where you want to log only value changes. 1/1/1 is your "virtual" object which is logged, 2 is minimum delta between current "virtual" object value which causes new value to be sent. Adjust as needed.
Code:checkupdate('1/1/1', 2)
As for storage, do you mean script storage? In newer releases it's stored in a separate database and there's no easy way to delete some of the entries unless you know all of their names. You can only do a full clear operation.
By the way, is there any way i could check objects previous state before the database update and without using storage?
For the second question I mean storage used by storage.get and storage.set
Thank you in advance
George
