17.03.2021, 01:02
(12.03.2021, 09:01)admin Wrote: Create an event script attached to a 1-byte unsigned object (valid scene number is from 1 to 15), change CM-19 address (default is 1) and port (default is /dev/RS485-1) if needed.
Code:addr = 1 -- CM-19 address (default 1) scene = event.getvalue() if scene > 0 and scene < 16 then value = string.format('!BR%dg%X;', addr, scene) port = require('serial').open('/dev/RS485-1', { baudrate = 9600, duplex = 'half' }) port:write(value) port:close() end
Thanks admin support.
