[OLD] LogicMachine firmware 2021.04
New FW here: https://forum.logicmachine.net/showthread.php?tid=3358
Changes from 2020 RC3
2020.07.27   scripting editor:   - add save action for CTRL+S   - clear undo history on load so CTRL+Z does not clear the whole script   - fix indentation error for "e", "n", "d" characters 2020.08.19   visualization: fix layout issue on certain configurations with slider in RGBW widget 2020.08.24   trends: add automatic trend log file creation if file is missing or corrupted   visualization: fix pin code for string types 2020.08.28   bacnet: add custom device name setting 2020.09.24   modbus: add status object for slave devices 2020.09.25   storage: add mosaic keys to ignore list   localbus: add "nobuswrite" field to event table for to grp.update   visualizaion: enable top bar work-around for iOS v11+ instead of only v11   visualizaion: fix positioning for nested widgets   visualizaion: small style fix for touch/mobile visualization 2020.09.30   visualization: add option to hide home button in touch mode 2020.10.12   modbus: add support for writing values with bitmask 2020.10.15   lm: add password support to knxproj import 2020.10.23   user access:   - add enable/disable option   - add per-app access control   - cache acl instead of using db queries for each request   - add optional object access list 2020.10.27   user access: add per-room user access to mosaic 2020.10.29   modbus: fix polling sequence for longer polling times   lm: add dali test result data type   trends: change heartbeat from 120 seconds to 1 week (604800 seconds)   trends: fix yearly display for min/max/last   schedulers: add missing doctype   vis: set fixed size for navbar buttons 2020.11.02   modbus: add TCP option to read test UI 2020.11.03   user access: show apps/mosaic/advanced access 2020.11.11   user access: add cloud login field 2020.11.12   visualization: fix control scaling for webkit browsers   vis.params: fix 4-bit params not saving due to duplicate window id 2020.11.26   knx filtering (IP/per-user): allow double asterisk (1/*/*)   bacnet client: move scandevice/scandevices functions to the bacnet library   modbus: allow read_count/read_offset usage for coils as well as registers   scripting editor: show current value when running an event script   visualization: use correct decimal settings for graph element 2020.11.30   bacnet: show correct device name in object list   http: add "x-frame-options: sameorigin" header with an option to disable it   trends: fix labels not showing in certain cases   user access: add cloud user list to cached acl 2020.12.02   knxproj import: use datatype from group connection if possible   trends: show error message when trend load fails due to a missing trend file 2020.12.11   trends: do not hide export button when a single trend is displayed   modbus: cache and reuse persistent TCP connections based on IP:PORT pair 2020.12.18   user access: log/block access attempts with unknown username   objects: fix pagination display after reload when filtering is active   apps: hide core apps from the list when user has no access to this module 2021.01.05   scenes: fix scene.tagset() function 2021.01.06   security: add "X-Content-Type-Option: nosniff" header to user uploads 2021.01.18   knx/ip: fix secure mode timer and duplicate message tag after outdated frame has been received 2021.01.19   modbus: ignore devices with polling time less than zero, try writing once in 60 seconds for devices marked as offline 2021.01.21   security: disallow KNX/IP Tunneling connections from external IPs 2021.01.22   system config: fix ntp client disable not being allowed with empty peer list   modbus: fix writing address when read_offset is used   modbus: fix write_address field missing in the database   modbus: try reading only once for devices that are marked offline 2021.02.03   modbus: fix mapping sorting by type/address 2021.02.04   modbus: add NaN check for floating point values after conversion when value_nan is not set   modbus: add missing value_default field 2021.02.22   system config: add user accounts and passwords to backup/restore 2021.03.22   schedulers: fix minor layout issues, fix race condition when one scheduler sets status for another 2021.03.23   user access: allow "+" in local/cloud login 2021.03.25   flashsys: do a full backup (not partial which can skip trends) before doing the fw upgrade   visualization editor: show icon when the object value is empty, otherwise it's not possible to select/move this object 2021.03.29   user access: hide removed apps from the access list 2021.04.08   storage: memory usage optimizations for large requests
[OLD] LogicMachine firmware 2021.04 - by admin - 13.04.2021, 13:27
