email?
Couple of things to check:
1) Make sure DNS and DG are set correct in the interface settings (otherwise you have no internet access)
2) Enable https://myaccount.google.com/lesssecureapps on your gmail account (otherwise mail from machines is blocked by google)
3) Use these settings in the common functions:
-- send an e-mail function mail(to, subject, message)   -- make sure these settings are correct   local settings = {     -- "from" field, only e-mail must be specified here     from = 'yourmail@gmail.com',     -- smtp username     user = 'yourmail@gmail.com',     -- smtp password     password = 'yoursecretpassword',     -- smtp server     server = 'smtp.gmail.com',     -- smtp server port     port = 465,     -- enable tls, required for gmail smtp     secure = 'tlsv1_2',   }   local smtp = require('socket.smtp')   if type(to) ~= 'table' then     to = { to }   end   for index, email in ipairs(to) do     to[ index ] = '<' .. tostring(email) .. '>'   end   -- fixup from field   local from = '<' .. tostring(settings.from) .. '>'   -- message headers and body   settings.source = smtp.message({     headers = {       to = table.concat(to, ', '),       subject = subject,       ['From'] = from,       ['Content-type'] = 'text/html; charset=utf-8',     },     body = message   })   settings.from = from   settings.rcpt = to   res, err = smtp.send(settings)   return res,err end
4) Send a mail
subject = 'E-mail test' message = 'Testing e-mail' res, err = mail('yourrecipient@gmail.com', subject, message)
email? - by Fred - 08.05.2021, 21:44
RE: email? - by Erwin van der Zwart - 09.05.2021, 08:28
