Integration with Satel alarm system via ETHM-1
I have a script for a read the states of inputs. But I have a little problem in my resident script. I cannot use grp.write() or grp.update() because I have this error:
Line 0: attempt to call field 'rshift' (a nil value)
I've tried send the same in the other script and there was ok.
This is my script:
-- Integracja z systemem Satelem po TCP cmd = string.char(0xFE,0xFE,0x00,0xD7,0xE2,0xFE,0x0D) bytes = 23 -- function Satel(cmd, bytes) function satel_send(cmd, bytes) ethm_ip = '192.168.2.9' port = 7094 socket = require('socket') client=socket.tcp() success, error = client:connect(ethm_ip, port) if success == 1 and error == nil then client:settimeout(0.3) client:send(cmd) data, error, partial = client:receive(bytes) -- error if not data then data = partial end client:close()     end   return data end   -- Funkcja odpowiedzialna za wyciągniecie poszczególnych bitów i wstawienie ich do tabeli function convert(data)  local res, byte  res = {}  for i = 1, #data do    -- get single byte    byte = data:byte(i, i)    byte = string.char(byte)    bits = hex2bin(byte)    for b = 1, #bits do    -- get single bit    bit = bits:byte(b, b)    bit = string.char(bit)    if bit == '0' then      bin = false    elseif bit =='1' then      bin = true    end    -- add to result    res[i*4-(4-b)] = bin    end  end  return res end data = satel_send(cmd, bytes) -- check if some data is available if data then data = lmcore.strtohex(data, true) -- delete first 4 and last 8 chars data = string.sub(data, 5, (string.len(data) -8)) inputs = convert(data) else log('Satel: zajęty') end -- update the inputs in the LM database for i = 1, #inputs do GA = '0/0/'.. tostring(91+i-1) grp.update(GA , inputs[i]) end
RE: Integration with Satel alarm system via ETHM-1 - by buuuudzik - 25.10.2016, 14:43
