02.11.2021, 06:39
(13.04.2021, 13:59)idhe Wrote: Ok thanksĀ admin, I found the solution in the lua doc : https://openrb.com/docs/lua.htm#grp.create
Can you share the solution please ?
I need that also.
Regards
Script change object range values
02.11.2021, 06:39
(13.04.2021, 13:59)idhe Wrote: Ok thanksĀ admin, I found the solution in the lua doc : https://openrb.com/docs/lua.htm#grp.create Hi, Can you share the solution please ? I need that also. Regards |
| Messages In This Thread |
Script change object range values - by idhe - 07.04.2021, 08:17
RE: Script change object range values - by davidchispas - 07.04.2021, 15:12
RE: Script change object range values - by admin - 07.04.2021, 15:19
RE: Script change object range values - by idhe - 07.04.2021, 16:33
RE: Script change object range values - by idhe - 13.04.2021, 13:59
RE: Script change object range values - by savaskorkmaz - 02.11.2021, 06:39
RE: Script change object range values - by admin - 02.11.2021, 08:06
