Philips HUE Lamps state
(15.12.2021, 14:09)Erwin van der Zwart Wrote: Yes you can control by name by adding these 2 functions to your user.hue:
function makeLightsTable()   local lights = getHueLights()   if lights then     lights = json.pdecode(lights)     LightsTable = {}     for _, foundlights in pairs(lights) do       LightsTable[foundlights.name] = tonumber(_)     end     storage.set("hue:lights", LightsTable)   end   return LightsTable end function makeGroupsTable()   local groups = getHueGroups()   if groups then     groups = json.pdecode(groups)     GroupsTable = {}     for _, foundgroups in pairs(groups) do       GroupsTable[foundgroups.name] = tonumber(_)     end     storage.set("hue:groups", GroupsTable)   end   return GroupsTable end
Then add this as a resident script at 0 seconds:
--Create lights and groups table (resident at 0) require('user.hue') makeLightsTable() makeGroupsTable() os.sleep(600)
From now on you can get the lamp ID by name using this:
lamp_id = storage.get("hue:lights")["Plafondlamp Woonkamer"] or 0 body_msg = '{"on":false}' sendToLight(lamp_id,body_msg) -- or group_id = storage.get("hue:groups")["Woonkamer"] or 0 body_msg = '{"on":true}' sendToGroup(group_id,body_msg)
PS: You are correct, there once was a mistake in a older user.hue lib with the sendToGroup function, it was already corrected in my latest version(s)
Sorry, I don't understand... I can already control on/off and 0-100% brightness.... How I could use that system?  What I need is to set and feedback of RGB COLOURS....
Philips HUE Lamps state - by gdimaria - 21.09.2021, 15:18
RE: Philips HUE Lamps state - by admin - 22.09.2021, 12:54
RE: Philips HUE Lamps state - by gdimaria - 22.09.2021, 15:34
RE: Philips HUE Lamps state - by gdimaria - 14.12.2021, 17:44
RE: Philips HUE Lamps state - by gdimaria - 15.12.2021, 14:47
RE: Philips HUE Lamps state - by admin - 15.12.2021, 05:50
RE: Philips HUE Lamps state - by gdimaria - 15.12.2021, 13:53
RE: Philips HUE Lamps state - by gdimaria - 16.12.2021, 07:02
RE: Philips HUE Lamps state - by gdimaria - 16.12.2021, 12:32
RE: Philips HUE Lamps state - by gdimaria - 25.01.2022, 13:09
