Storage is pushed on localbus
I have a resident script with interval 0 that is reading out a 'smart' electrical meter (dutch). The meter pushes a new telegram out every second. Which gets parsed and processed by the script. First question, what does the interval 0 mean? Is it run continiously? Does this have negative effects? It seems to work fine...
To save data between script iterations I use the storage. I save quite a lot of parameters to the storage since the data requires some processing to be useable in trends. I have noticed that this in turn results in a 'heavy' load of the websocket (localbus) since every set storage is pushed out the socket. Is there a way to prevent this? What is the best way to save data between iterations? I can think of one improvement and this is to try and save data in a table instead of separate parameters but this still will be pushed trough the localbus...
The script below:
lastchar = '!' require('serial') port = serial.open('/dev/ttyUSB0', { -- Let op type van de slimme meter voor de onderstaande instellingen.   baudrate = 115200,             --DSMR 2/3 = 9600        DSMR 4 = 115200   databits = 8,                    --DSMR 2/3 = 7            DSMR 4 = 8   stopbits = 1,                    --DSMR 2/3 = 1            DSMR 4 = 1   parity = 'none',            --DSMR 2/3 = even        DSMR 4 = none   duplex = 'full' }) function readdata(port)   local char, buf   buf = {}   while true do     char = port:read(1)     -- error (timeout) or newline, stop     if char == nil or char == lastchar then       break     -- ignore cr char     elseif char ~= '\r' then       table.insert(buf, char)     end   end   return table.concat(buf) end function splitString(s, delimiter)     local result = {};     for match in string.gmatch(s, "([^"..delimiter.."]+)") do                     table.insert(result, match);     end     return result; end function parseTelegram(data)          local parsed = {}    for line in data:gmatch("([^\n]*)\n?") do     local pristineLine = string.gsub(string.sub(line, 5), "%)", "")         local keyValue = splitString(pristineLine, "%(")     if (keyValue[1]) then         parsed[keyValue[1]] = keyValue[2]     end     end    return parsed end data = readdata(port) port:flush() --------------------------------------------------------------- dailyConsumption = storage.get('dailyConsumption') dailyInjection = storage.get('dailyInjection') intervalConsumption = storage.get('intervalConsumption') intervalInjection = storage.get('intervalInjection') intervalPoints = storage.get('intervalPoints') baseDayConsumption = storage.get('baseDayConsumption') baseDayInjection = storage.get('baseDayInjection') baseNightConsumption = storage.get('baseNightConsumption') baseNightInjection = storage.get('baseNightInjection') parsed = parseTelegram(data) totalDayConsumption = tonumber(splitString(parsed["1.8.1"], "%*")[1]) totalDayInjection = tonumber(splitString(parsed["2.8.1"], "%*")[1]) totalNightConsumption = tonumber(splitString(parsed["1.8.2"], "%*")[1]) totalNightInjection = tonumber(splitString(parsed["2.8.2"], "%*")[1]) currentConsumption = tonumber(splitString(parsed["1.7.0"], "%*")[1]) currentInjection = tonumber(splitString(parsed["2.7.0"], "%*")[1]) now = os.date('*t') if ((not dailyConsumption)) then   dailyConsumption = 0 end if ((not dailyInjection)) then   dailyInjection = 0 end if (not intervalConsumption) then   intervalConsumption = currentConsumption end if (not intervalInjection) then   intervalInjection = currentInjection end if (not intervalPoints) then   intervalPoints = 0 end intervalPoints = intervalPoints + 1 if ((not baseDayConsumption)) then    baseDayConsumption = totalDayConsumption   storage.set('baseDayConsumption', baseDayConsumption) end if ((not baseDayInjection)) then   baseDayInjection = totalDayInjection   storage.set('baseDayInjection', baseDayInjection) end if ((not baseNightConsumption)) then   baseNightConsumption = totalNightConsumption   storage.set('baseNightConsumption', baseNightConsumption) end if ((not baseNightInjection)) then   baseNightInjection = totalNightInjection   storage.set('baseNightInjection', baseNightInjection) end currentConsumtionPhase1 = tonumber(splitString(parsed["21.7.0"], "%*")[1]) currentConsumtionPhase2 = tonumber(splitString(parsed["41.7.0"], "%*")[1]) currentConsumtionPhase3 = tonumber(splitString(parsed["61.7.0"], "%*")[1]) currentInjectionPhase1 = tonumber(splitString(parsed["22.7.0"], "%*")[1]) currentInjectionPhase2 = tonumber(splitString(parsed["42.7.0"], "%*")[1]) currentInjectionPhase3 = tonumber(splitString(parsed["62.7.0"], "%*")[1]) intervalConsumption = intervalConsumption + currentConsumption intervalInjection = intervalInjection + currentInjection dailyConsumption = dailyConsumption + (currentConsumption * (1/3600)) storage.set('dailyConsumption', dailyConsumption) dailyInjection = dailyInjection + (currentInjection * (1/3600)) storage.set('dailyInjection', dailyInjection) if (math.fmod(now["min"], 5) == 0 and now["sec"] == 0) then     grp.write('x/x/x', dailyConsumption)   grp.write('x/x/x', dailyInjection)   grp.write('x/x/x', intervalConsumption / intervalPoints)   grp.write('x/x/x', intervalInjection / intervalPoints)   grp.write('x/x/x', currentConsumtionPhase1)   grp.write('x/x/x', currentConsumtionPhase2)   grp.write('x/x/x', currentConsumtionPhase3)     grp.write('x/x/x', currentInjectionPhase1)   grp.write('x/x/x', currentInjectionPhase2)   grp.write('x/x/x', currentInjectionPhase3)   storage.set('intervalConsumption', nil)   storage.set('intervalInjection', nil)   storage.set('intervalPoints', nil) else     storage.set('intervalConsumption', intervalConsumption)   storage.set('intervalInjection', intervalInjection)   storage.set('intervalPoints', intervalPoints) end if (now["min"] == 0 and now["sec"] == 0) then     grp.write('32/6/8', totalDayConsumption - baseDayConsumption)   grp.write('x/x/x', totalDayInjection - baseDayInjection)   grp.write('x/x/x', totalNightConsumption - baseNightConsumption)   grp.write('x/x/x', totalNightInjection - baseNightInjection) end -- At the end of the day after all was set, reset the values for the next day if ((now["hour"] == 0 and now["min"] == 0 and now["sec"] == 0)) then   dailyConsumption = 0   grp.write('x/x/x', dailyConsumption)   storage.set('dailyConsumption', dailyConsumption) end if ((now["hour"] == 0 and now["min"] == 0 and now["sec"] == 0)) then   dailyInjection = 0   grp.write('x/x/x', dailyInjection)   storage.set('dailyInjection', dailyInjection) end if ((now["hour"] == 0 and now["min"] == 0 and now["sec"] == 0)) then   log('reset consumption for day')   baseDayConsumption = totalDayConsumption   grp.write('x/x/x', totalDayConsumption - baseDayConsumption)   storage.set('baseDayConsumption', baseDayConsumption) end if ((now["hour"] == 0 and now["min"] == 0 and now["sec"] == 0)) then   baseDayInjection = totalDayInjection   grp.write('x/x/x', totalDayInjection - baseDayInjection)   storage.set('baseDayInjection', baseDayInjection) end if ((now["hour"] == 0 and now["min"] == 0 and now["sec"] == 0)) then   baseNightConsumption = totalNightConsumption   grp.write('x/x/x', totalNightConsumption - baseNightConsumption)   storage.set('baseNightConsumption', baseNightConsumption) end if ((now["hour"] == 0 and now["min"] == 0 and now["sec"] == 0)) then   baseNightInjection = totalNightInjection   grp.write('x/x/x', totalNightInjection - baseNightInjection)   storage.set('baseNightInjection', baseNightInjection) end
Any advise would be appreciated!
Kind regards
Storage is pushed on localbus - by Smeagol - 23.12.2021, 19:00
RE: Storage is pushed on localbus - by admin - 24.12.2021, 08:28
RE: Storage is pushed on localbus - by Bitver - 24.12.2021, 15:07
RE: Storage is pushed on localbus - by admin - 24.12.2021, 15:10
