Waterkotte Ecotouch Heatpump
@admin: Many thanks again for your big help! Highly appreciated!
I made two script sets out of it.
The first one is to read the actual values I'm interested in:
http = require('socket.http') ip = 'xxx' -- ip address of Waterkotte heat pump user = 'xxx' -- username of web interface pwd = 'xxx' -- password of web interface url = 'http://' .. ip .. '/cgi/login?username=' .. user .. '&password=' .. pwd res, code = http.request(url) log('login request', res, code) if res and code == 200 then   token = res:match('IDALToken=(%x+)')   log('token', token)   if type(token) == 'string' and #token == 32 then     storage.set('ecotouch-token', token)   end end -- Read actual hot water temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A19'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code)     value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/1', value/10)    end end os.sleep(1)      -- Read actual source in temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A4'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/2', value/10)    end end os.sleep(1)      -- Read actual source out temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A5'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/3', value/10)    end end os.sleep(1)      -- ************************************************************ -- Read actual return temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A11'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/4', value/10)    end end os.sleep(1)      -- Read actual flow temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A12'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/5', value/10)    end end os.sleep(1)      -- ************************************************************ -- Read actual power compressor **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A25'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/6', value/10)    end end os.sleep(1)      -- Read actual power heating**************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A26'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/7', value/10)    end end os.sleep(1)      -- Read actual COP*************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A28'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/1/8', value/10)    end end -- Read desrired hot water temperature **************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=A37'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code)     value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)       grp.checkupdate('46/3/1', value/10)    end end os.sleep(1)    -- Read status heeting mode**************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=I30'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code)     value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)         if value == 1             then             value = true             elseif             value == 0             then             value = false         end       grp.checkupdate('46/3/2', value)    end end os.sleep(1)    -- Read status cooling mode**************************** if token then   url = 'http://' .. ip .. '/cgi/readTags?n=1&t1=I31'   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code)     value = res:match('S_OK%s+%d+%s+(%d+)')    if value then       value = tonumber(value)    -- log(value)         if value == 1             then             value = true             elseif             value == 0             then             value = false         end       grp.checkupdate('46/3/3', value)    end end os.sleep(1)
And the second one to write the desired values:
http = require('socket.http') ip = 'xxx' -- ip address of Waterkotte heat pump user = 'xxx' -- username of web interface pwd = 'xxx' -- password of web interface url = 'http://' .. ip .. '/cgi/login?username=' .. user .. '&password=' .. pwd res, code = http.request(url) log('login request', res, code) if res and code == 200 then   token = res:match('IDALToken=(%x+)')   log('token', token)   if type(token) == 'string' and #token == 32 then     storage.set('ecotouch-token', token)   end end os.sleep(1) -- Write enable heating mode **************************** setvalue = grp.getvalue('46/2/2') if setvalue == true then setvalue = 1     else setvalue = 0 end if token then   url = 'http://' .. ip .. '/cgi/writeTags?returnValue=true&n=1&t1=I30&v1='..setvalue   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code)     end os.sleep(1) -- Write enable cooling mode **************************** setvalue = grp.getvalue('46/2/3') if setvalue == true then setvalue = 1     else setvalue = 0 end if token then   url = 'http://' .. ip .. '/cgi/writeTags?returnValue=true&n=1&t1=I31&v1='..setvalue   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) end os.sleep(1) -- Write water temperature**************************** setvalue = grp.getvalue('46/2/1') setvalue = setvalue *10 if token then   url = 'http://' .. ip .. '/cgi/writeTags?returnValue=true&n=1&t1=A38&v1='..setvalue   res, code = http.request({     url = url,     headers = {       ['Cookie'] = 'IDALToken=' .. token     }   })   log('read request', res, code) end
Generally it works fine EXCEPT when the time between two request is to short I getting the following return in the log and the values are not written to the heatpump:
Waterkotte_Sollwerte 10.03.2022 20:23:55 * arg: 1   * string: login request * arg: 2   * string: -37 #E_TOO_MANY_USERS * arg: 3   * number: 200
@admin: Do you have an idea how to control the situation? Do I need to detect: "#E_TOO_MANY_USERS" and then wait some second and resend? How would this look like? Many thanks for your help!
RE: Waterkotte Ecotouch Heatpump - by admin - 07.03.2022, 08:27
RE: Waterkotte Ecotouch Heatpump - by admin - 08.03.2022, 08:09
RE: Waterkotte Ecotouch Heatpump - by admin - 08.03.2022, 09:46
RE: Waterkotte Ecotouch Heatpump - by pioneersteffen - 10.03.2022, 19:35
RE: Waterkotte Ecotouch Heatpump - by admin - 11.03.2022, 09:22
