Renewing SSL certificate
(11.12.2020, 07:39)admin Wrote: The script that you've provided won't work on LM. At this point it's not possible to fully automate this process without an external server. We have plans to add a service that uses LetsEncrypt for fully automated certificate issue and renewal but I can't tell you when it's going live.
For now you can replace the current key/certificate like this:
require('json') -- data from privkey.pem key = [[ -----BEGIN PRIVATE KEY----- ... -----END PRIVATE KEY----- ]] -- data from fullchain.pem crt = [[ -----BEGIN CERTIFICATE----- ... -----END CERTIFICATE----- -----BEGIN CERTIFICATE----- ... -----END CERTIFICATE----- ]] json.data = function()   return {     values = {       mode = 'set',       key = key,       crt = crt,     }   } end stat, res = pcall(dofile, '/lib/flashsys/httpd_crt/save.lua') if stat then   res = json.pdecode(res)   log(res)   os.execute('/etc/init.d/nginx reload') else   log('error', res) end
Hello Admin:
Is there anyway to fully automate the LetsEncrypt certificates?
best regards
Renewing SSL certificate - by buuuudzik - 09.12.2020, 23:02
RE: Renewing SSL certificate - by admin - 11.12.2020, 07:39
RE: Renewing SSL certificate - by batistacaceres - 06.05.2022, 11:10
RE: Renewing SSL certificate - by admin - 06.05.2022, 11:12
RE: Renewing SSL certificate - by admin - 06.05.2022, 11:33
RE: Renewing SSL certificate - by Leo681 - 06.06.2023, 15:23
