Weather Info from API
The updated version of weather script.
1.) Added possibility to read coordinates (latitude and longitude) from system.
2.) Changed data types of objects:
        a.) for humidity dt.scale
        b.) for uv_index dt.uint8
        c.) for pressure dt.uint16
-- Please comment objects which you are not using, comment also grp.write() at the bottom of script --[[ -- You can set latitude and longitude in "Date time" option -- go to LogicMachine->Utilities->Date and time require('uci') latitude = uci.get('genohm-scada.core.latitude') -- read latitude from system latitude = tonumber(latitude) or 0 longitude = uci.get('genohm-scada.core.longitude') -- read longitude from system longitude = tonumber(longitude) or 0 if(latitude == 0 and longitude == 0) then -- if cooridinates were not set in the system   latitude = 51.5072 -- London   longitude = 0.1276 -- London end --]] -- you can set latitude and longitude manualy -- (if you set coordinates using "Date time" do not forget to comment these two lines latitude = 56.9496  -- Riga longitude = 24.1052 -- Riga --log('latitude = ' .. latitude) --log('longitude = ' .. longitude) --[[ status_temp = '32/1/13'           -- group address of temperature, should be float status_pressure = '32/1/14'       -- air pressure, should be float status_humidity = '32/1/15'       -- relative humidity, should be float status_wind_direction = '32/1/16' -- wind direction, should be float status_wind_speed = '32/1/17'     -- wind speed, should be float status_uv_index = '32/2/4'        -- UV index, should be float status_feelslike_temp = '32/2/3'  -- feels like temperature, should be float status_rain_today = '32/1/11'     -- today's rain object, should be boolean status_snow_today = '32/1/12'     -- today's snow object, should be boolean status_min_temp_today = '32/1/20'       -- today's minimum air temperature, float status_max_temp_today = '32/1/21'       -- today's maximum air temperature, float status_min_pressure_today = '32/1/22'   -- minimum air pressure, float status_max_pressure_today = '32/1/23'   -- maximum air pressure, float status_min_wind_speed_today = '32/1/24' -- minimum wind speed, float status_max_wind_speed_today = '32/1/25' -- maximum wind speed, float status_min_uv_today = '32/2/5'          -- minimum UV today, float status_max_uv_today = '32/2/6'          -- maximum UV today, float status_rain_tomor = '32/1/9'   -- tomorrow's rain object status_snow_tomor = '32/1/10'  -- tomorrow's snow object status_min_temp_tomor = '32/1/26' status_max_temp_tomor = '32/1/27' status_min_pressure_tomor = '32/1/28' status_max_pressure_tomor = '32/1/29' status_min_wind_speed_tomor = '32/1/30' status_max_wind_speed_tomor = '32/1/31' status_min_uv_tomor = '32/2/7' status_max_uv_tomor = '32/2/8' --]] --[[]] status_temp = grp.create({ datatype = dt.float16, address = '33/1/1', name = 'current_temp',}) status_pressure = grp.create({ datatype = dt.uint16, address = '33/1/2', name = 'current_press',}) status_humidity = grp.create({ datatype = dt.scale, address = '33/1/3', name = 'current_humid',}) status_wind_direction = grp.create({ datatype = dt.float16, address = '33/1/4', name = 'current_wind_dir',}) status_wind_speed = grp.create({ datatype = dt.float16, address = '33/1/5', name = 'current_wind_sp',}) status_uv_index = grp.create({ datatype = dt.uint8, address = '33/1/6', name = 'current_uv_index',}) status_feelslike_temp = grp.create({ datatype = dt.float16, address = '33/1/7', name = 'current_feels_temp',}) status_rain_today = grp.create({ datatype = dt.bool, address = '33/1/8', name = 'rain_today',}) status_snow_today = grp.create({ datatype = dt.bool, address = '33/1/9', name = 'snow_today',}) status_min_temp_today = grp.create({ datatype = dt.float16, address = '33/1/10', name = 'today_temp_min',}) status_max_temp_today = grp.create({ datatype = dt.float16, address = '33/1/11', name = 'today_temp_max',}) status_min_pressure_today = grp.create({ datatype = dt.uint16, address = '33/1/12', name = 'today_press_min',}) status_max_pressure_today = grp.create({ datatype = dt.uint16, address = '33/1/13', name = 'today_press_max',}) status_min_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/14', name = 'today_wind_min',}) status_max_wind_speed_today = grp.create({ datatype = dt.float16, address = '33/1/15', name = 'today_wind_max',}) status_min_uv_today = grp.create({ datatype = dt.uint8, address = '33/1/16', name = 'today_uv_min',}) status_max_uv_today = grp.create({ datatype = dt.uint8, address = '33/1/17', name = 'today_uv_max',}) status_rain_tomor = grp.create({ datatype = dt.bool, address = '33/1/18', name = 'rain_tomor',}) status_snow_tomor = grp.create({ datatype = dt.bool, address = '33/1/19', name = 'snow_tomor',}) status_min_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/20', name = 'tomor_temp_min',}) status_max_temp_tomor = grp.create({ datatype = dt.float16, address = '33/1/21', name = 'tomor_temp_max',}) status_min_pressure_tomor = grp.create({ datatype = dt.uint16, address = '33/1/22', name = 'tomor_press_min',}) status_max_pressure_tomor = grp.create({ datatype = dt.uint16, address = '33/1/23', name = 'tomor_press_max',}) status_min_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/24', name = 'tomor_wind_min',}) status_max_wind_speed_tomor = grp.create({ datatype = dt.float16, address = '33/1/25', name = 'tomor_wind_max',}) status_min_uv_tomor = grp.create({ datatype = dt.uint8, address = '33/1/26', name = 'tomor_uv_min',}) status_max_uv_tomor = grp.create({ datatype = dt.uint8, address = '33/1/27', name = 'tomor_uv_max',}) --]] rain_tod_YR = false        -- is rainy or not (for today) snow_tod_YR = false        -- is snowy or not (for today) rain_tom_YR = false        -- is rainy or not (for tomorrow) snow_tom_YR = false        -- is snowy or not (for tomorrow) -- current temperature, air pressure, humidity, wind direction and speed temperature_YR = -273    -- temperature in degree Celsius air_pressure_YR = -1     -- air pressure in hPa humidity_YR = -1         -- air humidity in % wind_direction_YR = -1   -- wind direction in degrees [0; 360) wind_speed_YR = -1       -- wind speed in m/s uv_index_YR = -1         -- UV index feelslike_temp_YR = -273 -- feels like temperature in degree Celsius function init_min_max_table() -- initialize table for minimum, maximum temperature, pressure, windspeed   local min_max = {}   min_max.min_t = 8000 -- minimum temperature for today   min_max.max_t = -273 -- maximum temperature for today   min_max.min_p = 8000 -- minimum pressure for today   min_max.max_p = -1   -- maximum pressure for today   min_max.min_w = 8000 -- minimum wind speed for today   min_max.max_w = -1   -- maximum wind speed for today   min_max.min_uv = 8000 -- minimum UV index   min_max.max_uv = -1   -- maximum UV index     return min_max end function set_timestamp(day) -- if day = 0 today; if day = 1 tomorrow, if day = 2 day after tomorrow   local date = os.date('*t')   date.day = date.day + day   local time = os.time(date)   return os.date('%Y-%m-%d', time), date.hour -- timestamp and current hour end -- minimum maximum values of temperature, pressure and windspeed function min_max_temp_press_wind(dat_tab, min_max_tab)   min_max_tab.min_t = math.min(min_max_tab.min_t, dat_tab.air_temperature or 8000)   min_max_tab.max_t = math.max(min_max_tab.max_t, dat_tab.air_temperature or -273)   min_max_tab.min_p = math.min(min_max_tab.min_p, dat_tab.air_pressure_at_sea_level or 8000)   min_max_tab.max_p = math.max(min_max_tab.max_p, dat_tab.air_pressure_at_sea_level or -1)   min_max_tab.min_w = math.min(min_max_tab.min_w, dat_tab.wind_speed or 8000)   min_max_tab.max_w = math.max(min_max_tab.max_w, dat_tab.wind_speed or -1)   min_max_tab.min_uv = math.min(min_max_tab.min_uv, dat_tab.ultraviolet_index_clear_sky or 8000)   min_max_tab.max_uv = math.max(min_max_tab.max_uv, dat_tab.ultraviolet_index_clear_sky or -1)     return min_max_tab end function check_for_rain(next1h)   local is_rainy = false   local code = ''     if type(next1h) == 'table' and type(next1h.summary) == 'table' then     code = next1h.summary.symbol_code or ''   end     if code:find('rain') then     is_rainy = true   end     return is_rainy end function check_for_snow(next1h)   local is_snowy = false   local code = ''     if type(next1h) == 'table' and type(next1h.summary) == 'table' then     code = next1h.summary.symbol_code or ''   end     if code:find('snow') then     is_snowy = true   end   return is_snowy end function calc_heat_index(temperature, humidity)   if temperature < 26.7 then     log('for heat_index calculation temperature should be higher than +26.7 Celsius degree')     return -273   end     if humidity < 0 or humidity > 100 then     log('humidity should be in a range from 0 ... 100%')     return -273   end     local T = temperature   local H = humidity   local c_1 = -8.785   local c_2 = 1.611   local c_3 = 2.339   local c_4 = -0.146   local c_5 = -0.0123   local c_6 = -0.0164   local c_7 = 0.00221   local c_8 = 0.000725   local c_9 = -0.00000358   local heat_index = c_1+c_2*T+c_3*H+c_4*T*H+c_5*T*T+c_6*H*H+c_7*T*T*H+c_8*T*H*H+c_9*T*T*H*H       return heat_index end function calc_wind_chill(temperature, wind_speed)   if temperature > 10 then     log('temperature should be less than +10.0 Celsius degree')       return -273   end       if wind_speed < 0 or wind_speed > 49.2 then       log('wind speed should be in a range 0 ... 49.2 m/s')     return -273   end     local T_air = temperature -- air temperature Celsius degree     local a = 0.62 -- coef   local b = 0.51 -- coef   local T_1 = 13.1 -- Celsius degree   local T_2 = 14.6 -- Celsius degree     local M_0 = 1.3333 -- m/s   local M = wind_speed -- m/s     local T_wind_chill     if M > M_0 then     T_wind_chill = (a*T_air + T_1) + (b*T_air - T_2)*(M/M_0)^0.16   else     T_wind_chill = T_air   end     return T_wind_chill end function calc_feelslike(temperature, wind_speed, humidity)   local T_feelslike     if temperature <= 10.0 then -- if less than 10.0 Celsius degree (or equal) then wind chill     T_feelslike = calc_wind_chill(temperature, wind_speed)   elseif temperature >= 26.7 then -- if more than 26.7 Celsius degree (or equal) then heat index     T_feelslike = calc_heat_index(temperature, humidity)   else -- other cases just return temperature     T_feelslike = temperature   end   return T_feelslike end min_max_today = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction min_max_tomor = init_min_max_table() -- table for minimum maximum temperature, air pressure, wind direction json = require('json') http = require('socket.http') args = 'lat=' .. latitude .. '&lon=' .. longitude --url = 'https://api.met.no/weatherapi/locationforecast/2.0/compact?' .. args url = 'https://api.met.no/weatherapi/locationforecast/2.0/complete?' .. args mac = 0 io.readfile('/sys/class/net/eth0/address'):gsub('%x%x', function(v)   mac = mac * 256 + tonumber(v, 16) end) http.USERAGENT = 'LM ' .. mac res, err = http.request(url) data = json.pdecode(res) if type(data) == 'table' then   timestamp, hour = set_timestamp(0) -- current day     if hour < 10 then     timestamp_current_hour = timestamp .. 'T0' .. hour .. ':00:00Z' -- time stamp for current hour   else     timestamp_current_hour = timestamp .. 'T' .. hour .. ':00:00Z'  -- time stamp for current hour   end     --log('timestamp = ' .. timestamp)     timestamp_next = set_timestamp(1) -- timestamp for tomorrow   --log('timestamp_next = ' .. timestamp_next)     --timestamp_after_next = set_timestamp(2) -- timestamp for day after tomorrow   --log('timestamp_after_next = ' .. timestamp_after_next)     --timestamp_after_after = set_timestamp(3) -- timestamp for day after day after tomorrow   --log('timestamp_after_after = ' .. timestamp_after_after)     for i, entry in ipairs(data.properties.timeseries) do          -- for weather now     if entry.time == timestamp_current_hour then -- get data only for one hour (current hour)       current_data = entry.data.instant.details       if type(current_data) == 'table' then         temperature_YR = current_data.air_temperature or -273           -- temperature in Celsius degree         air_pressure_YR = current_data.air_pressure_at_sea_level or -1  -- air pressure in hPa         humidity_YR = current_data.relative_humidity or -1              -- air humidity in %         wind_direction_YR = current_data.wind_from_direction or -1      -- wind direction in degrees [0;360)         wind_speed_YR = current_data.wind_speed or -1                   -- wind speed in m/s         uv_index_YR = current_data.ultraviolet_index_clear_sky or -1    -- uv index         feelslike_temp_YR = calc_feelslike(temperature_YR, wind_speed_YR, humidity_YR) -- feels like temperature in Celsius degree       end     end         if entry.time:sub(1, #timestamp) == timestamp then -- checks remaining hours + 3 previous hours of current day         current_data = entry.data.instant.details       if type(current_data) == 'table' then         min_max_today = min_max_temp_press_wind(current_data, min_max_today)       end             if rain_tod_YR == false then -- if detected rain does not check for rain         rain_tod_YR = check_for_rain(entry.data.next_1_hours)       end             if snow_tod_YR == false then -- if detected snow does not check for snow         snow_tod_YR = check_for_snow(entry.data.next_1_hours)       end     end         if entry.time:sub(1, #timestamp_next) == timestamp_next then -- checks 24 hours of next day       tomor_data = entry.data.instant.details       if type(tomor_data) == 'table' then         min_max_tomor = min_max_temp_press_wind(tomor_data, min_max_tomor)       end             if rain_tom_YR == false then -- if detected rain does not check for rain         rain_tom_YR = check_for_rain(entry.data.next_1_hours)       end             if snow_tom_YR == false then -- if detected snow does not check for snow         snow_tom_YR = check_for_snow(entry.data.next_1_hours)       end     end     end     -- data for current hour   grp.write(status_temp, temperature_YR)   grp.write(status_pressure, air_pressure_YR)   grp.write(status_humidity, humidity_YR)   grp.write(status_wind_direction, wind_direction_YR)   grp.write(status_wind_speed, wind_speed_YR)   grp.write(status_uv_index, uv_index_YR)   grp.write(status_feelslike_temp, feelslike_temp_YR)       -- data for today: rain, snow; min and max for temperature, pressure, wind   grp.write(status_rain_today, rain_tod_YR)   grp.write(status_snow_today, snow_tod_YR)     grp.write(status_min_temp_today, min_max_today.min_t)   grp.write(status_max_temp_today, min_max_today.max_t)   grp.write(status_min_pressure_today, min_max_today.min_p)   grp.write(status_max_pressure_today, min_max_today.max_p)   grp.write(status_min_wind_speed_today, min_max_today.min_w)   grp.write(status_max_wind_speed_today, min_max_today.max_w)   grp.write(status_min_uv_today, min_max_today.min_uv)   grp.write(status_max_uv_today, min_max_today.max_uv)       -- data for tomorrow: rain, snow; min and max for temperature, pressure, wind   grp.write(status_rain_tomor, rain_tom_YR)   grp.write(status_snow_tomor, snow_tom_YR)     grp.write(status_min_temp_tomor, min_max_tomor.min_t)   grp.write(status_max_temp_tomor, min_max_tomor.max_t)   grp.write(status_min_pressure_tomor, min_max_tomor.min_p)   grp.write(status_max_pressure_tomor, min_max_tomor.max_p)   grp.write(status_min_wind_speed_tomor, min_max_tomor.min_w)   grp.write(status_max_wind_speed_tomor, min_max_tomor.max_w)   grp.write(status_min_uv_tomor, min_max_tomor.min_uv)   grp.write(status_max_uv_tomor, min_max_tomor.max_uv)   end
4. How often we can start this script?
You can run the script every four hours, should work fine.
.lua   my_script_v13.lua (Size: 15.57 KB / Downloads: 18)
Weather Info from API - by Fahd - 24.02.2022, 23:52
RE: Weather Info from API - by admin - 25.02.2022, 08:31
RE: Weather Info from API - by Mrinj - 27.05.2022, 13:14
RE: Weather Info from API - by admin - 27.05.2022, 13:19
RE: Weather Info from API - by Mrinj - 27.05.2022, 13:23
RE: Weather Info from API - by AlexLV - 08.06.2022, 05:51
RE: Weather Info from API - by RomansP - 08.06.2022, 08:52
RE: Weather Info from API - by AlexLV - 09.06.2022, 08:21
RE: Weather Info from API - by RomansP - 09.06.2022, 11:04
RE: Weather Info from API - by RomansP - 10.06.2022, 07:53
RE: Weather Info from API - by Mrinj - 22.06.2022, 08:00
RE: Weather Info from API - by Fahd - 22.06.2022, 09:59
RE: Weather Info from API - by RomansP - 22.06.2022, 08:17
RE: Weather Info from API - by Mrinj - 22.06.2022, 16:24
RE: Weather Info from API - by admin - 23.06.2022, 06:24
RE: Weather Info from API - by Mrinj - 23.06.2022, 06:36
RE: Weather Info from API - by Acla - 09.07.2022, 23:16
RE: Weather Info from API - by admin - 11.07.2022, 06:28
RE: Weather Info from API - by Acla - 11.07.2022, 21:30
RE: Weather Info from API - by RomansP - 12.07.2022, 06:20
RE: Weather Info from API - by fabiorusco - 31.10.2022, 10:48
RE: Weather Info from API - by RomansP - 31.10.2022, 13:48
RE: Weather Info from API - by fabiorusco - 03.11.2022, 06:51
RE: Weather Info from API - by fabiorusco - 03.11.2022, 13:07
RE: Weather Info from API - by RomansP - 03.11.2022, 14:44
RE: Weather Info from API - by fabiorusco - 03.11.2022, 15:09
RE: Weather Info from API - by P_marienborg - 17.01.2023, 09:15
RE: Weather Info from API - by admin - 17.01.2023, 09:15
RE: Weather Info from API - by alias74 - 09.06.2023, 08:07
