convert percentage to 3 digital outputs
Hi, is that what you need?
percent_val = event.getvalue() -- your value --the first 5-30%, the second between 35-70% and the third between 75-100%. first_obj = '5/0/1' -- address of first object second_obj = '5/0/2' -- address of second object third_obj = '5/0/3'  -- address of third object if(percent_val >= 0 and percent_val < 5) then -- turn off   grp.write(first_obj, 0) -- first object set to 0   grp.write(second_obj, 0) -- second object set to 0   grp.write(third_obj, 0) -- third object set to 0 elseif( percent_val >= 5 and percent_val <= 30 ) then   grp.write(first_obj, 1) -- first object set to 1   grp.write(second_obj, 0) -- second object set to 0   grp.write(third_obj, 0) -- third object set to 0 elseif( percent_val >= 35 and percent_val <= 70 ) then   grp.write(first_obj, 0)   grp.write(second_obj, 1)   grp.write(third_obj, 0) elseif( percent_val >= 75 and percent_val <= 100 ) then   grp.write(first_obj, 0)   grp.write(second_obj, 0)   grp.write(third_obj, 1) end
RE: convert percentage to 3 digital outputs - by RomansP - 14.06.2022, 10:03
