massive data logging
(14.09.2022, 11:33)admin Wrote: You only need to create a bucket once. It will store your data for a certain amount of time. There are examples of sending data to influx v2 in the topic I've linked to.
The setup part is a bit complicated but you only have to do it once Smile
I accepted the challenge! Smile
But right now I get error messages:
* arg: 1
  * string: error sending to influx
* arg: 2
  * string: {"code":"invalid","message":"at line 1:36: cannot parse value for field key \"value\": invalid float value syntax (check rejected_points in your _monitoring bucket for further information)"}
* arg: 3
  * number: 400
* arg: 4
  * string: rawdata,name=ora,addr=33/1/9 value=10:57
and
* arg: 1
* arg: 2
  * string: {"code":"invalid","message":"at line 1:47: cannot parse value for field key \"value\": invalid bool value \"Thu\" (check rejected_points in your _monitoring bucket for further information)"}
* arg: 3
  * number: 400
* arg: 4
  * string: rawdata,name=giornomeseanno,addr=33/1/8 value=Thu 15-09-2022
the script I used is the following, can you help me?
local socket = require('socket') local http = require('socket.http') http.TIMEOUT = 5 local dt_cache = {} function get_value(addr, datahex)   local dt = dt_cache[addr]   if(not dt) then     dt = grp.find(addr)     dt_cache[addr] = dt   end     return knxdatatype.decode(datahex, dt.datatype), dt end function knx_callback(event)   local addr = event.dst   local value, dt = get_value(addr, event.datahex)   send_metric('rawdata', dt.name, addr, value) end function send_metric(table, name, addr, value)   if name == nil or name == '' then     return   end   name = string.gsub(name, ' ', '\\ ')   local url = 'https://europe-west1-1.gcp.cloud2.influxdata.com/api/v2/write?bucket=XX&org=XXX'   local body   if type(value) == 'boolean' then     body = string.format('%s,name=%s,addr=%s state=%s', table, name, addr, value)   else     -- most likely number     body = string.format('%s,name=%s,addr=%s value=%s', table, name, addr, value)   end   local res, code = http.request({     url = url,     method = 'POST',     body = body,     headers = {       Authorization = 'Token XXXXXXXXXXXXXXXXXXX'     }   })   if code ~= 204 then     log('error sending to influx', res, code, body)   end end function run_loop()   local bus = require('localbus').new(1)   bus:sethandler('groupwrite', knx_callback)   local busfd = socket.fdmaskset(bus:getfd(), 'r')     while(true) do     res, fbus = socket.selectfds(10, busfd)     if(fbus) then       bus:step()     end   end end run_loop()
massive data logging - by gdimaria - 05.09.2022, 16:22
RE: massive data logging - by admin - 06.09.2022, 10:08
RE: massive data logging - by gdimaria - 07.09.2022, 07:42
RE: massive data logging - by admin - 07.09.2022, 07:47
RE: massive data logging - by gdimaria - 14.09.2022, 11:14
RE: massive data logging - by admin - 14.09.2022, 11:33
RE: massive data logging - by gdimaria - 15.09.2022, 09:05
RE: massive data logging - by admin - 15.09.2022, 09:23
RE: massive data logging - by gdimaria - 15.09.2022, 10:04
RE: massive data logging - by admin - 15.09.2022, 12:55
RE: massive data logging - by gdimaria - 16.09.2022, 10:26
RE: massive data logging - by admin - 19.09.2022, 06:10
